ESP-Prog sdcard issues
dizcza
Postby dizcza » Mon Nov 14, 2022 2:23 pm
I have an ESP-Prog attached to a TTGO T8 ESP32 board (JTAG interface only). As soon as I initialize the sd card, I cannot debug the app.
Here are the logs that works (NO SD CARD):
$ openocd -f interface/ftdi/esp32_devkitj_v1.cfg -f target/esp32.cfg
Open On-Chip Debugger v0.11.0-esp32-20221026 (2022-10-26-14:47)
Licensed under GNU GPL v2
For bug reports, read
adapter speed: 20000 kHz
Info : ftdi: if you experience problems at higher adapter clocks, try the command "ftdi tdo_sample_edge falling"
Info : clock speed 20000 kHz
Info : starting gdb server for esp32.cpu0 on 3333
Info : [esp32.cpu0] Debug controller was reset.
Info : [esp32.cpu0] Core was reset.
Info : [esp32.cpu1] Debug controller was reset.
Info : [esp32.cpu1] Core was reset.
Info : [esp32.cpu0] Target halted, PC=0x4008C192, debug_reason=00000000
Info : [esp32.cpu0] Reset cause (1) - (Power on reset)
Info : [esp32.cpu1] Target halted, PC=0x4008C192, debug_reason=00000000
Info : [esp32.cpu1] Reset cause (14) - (CPU1 reset by CPU0)
I also tried
$ openocd -f board/esp32-wrover-kit-3.3v.cfg
- same story.
Then I add
sdcard_mount_mmc();
in the main function, recompile and flash via USB, and see the following openocd logs:
Info : [esp32.cpu0] Target halted, PC=0x4000942F, debug_reason=00000000
Info : [esp32.cpu0] Target halted, PC=0x40064AE0, debug_reason=00000000
Error: [esp32.cpu1] Unexpected OCD_ID = 00000000
Info : [esp32.cpu1] Target halted, PC=0x40008547, debug_reason=00000000
Error: [esp32.cpu0] DSR (FFFFFFFF) indicates target still busy!
Error: [esp32.cpu0] DSR (FFFFFFFF) indicates DIR instruction generated an exception!
Error: [esp32.cpu0] DSR (FFFFFFFF) indicates DIR instruction generated an overrun!
Info : [esp32.cpu0] Target halted, PC=0xFFFFFFFF, debug_reason=00000000
Error: [esp32.cpu1] Unexpected OCD_ID = ffffffff
Info : Set GDB target to 'esp32.cpu0'
Info : [esp32.cpu0] Disabling LDDR32.P/SDDR32.P
Warn : [esp32.cpu0] Failed writing 4 bytes at address 0x3ff5f048
Error: Failed to write ESP32_TIMG0WDT_CFG0 (-4)!
Info : [esp32.cpu0] Target halted, PC=0x00000000, debug_reason=00000000
Info : [esp32.cpu0] Reset cause (63) - (Unknown reset cause)
Error: [esp32.cpu0] Timed out waiting for CPU to be reset, target state=0
Error: [esp32.cpu0] Failed to wait for target halt to read reset cause (0)!
Polling target esp32.cpu0 failed, trying to reexamine
Error: [esp32.cpu0] Unexpected OCD_ID = 00000000
Examination failed, GDB will be halted. Polling again in 100ms
Error: [esp32.cpu0] Timed out waiting for CPU to be reset, target state=1
Restarting the openocd does not help:
Error: JTAG scan chain interrogation failed: all zeroes
Error: esp32.cpu0: IR capture error; saw 0x00 not 0x01
Warn : target esp32.cpu0 examination failed
Warn : target esp32.cpu1 examination failed
I noticed an interesting behavior: when I do sdcard listing and try launching the openocd server at the same time, openocd logs are:
Info : TAP esp32.cpu0 does not have valid IDCODE (idcode=0xf8000000)
Info : TAP esp32.cpu1 does not have valid IDCODE (idcode=0xfc000000)
Info : TAP auto0.tap does not have valid IDCODE (idcode=0xfe000000)
Info : TAP auto1.tap does not have valid IDCODE (idcode=0xff000000)
Info : TAP auto2.tap does not have valid IDCODE (idcode=0xff800000)
Info : TAP auto3.tap does not have valid IDCODE (idcode=0xffc00000)
Info : TAP auto4.tap does not have valid IDCODE (idcode=0xffe00000)
Info : TAP auto5.tap does not have valid IDCODE (idcode=0xfff00000)
Info : TAP auto6.tap does not have valid IDCODE (idcode=0xfff80000)
Info : TAP auto7.tap does not have valid IDCODE (idcode=0xfffc0000)
Info : TAP auto8.tap does not have valid IDCODE (idcode=0xfffe0000)
Info : TAP auto9.tap does not have valid IDCODE (idcode=0x7fff0000)
Info : TAP auto10.tap does not have valid IDCODE (idcode=0x3fff8000)
Info : TAP auto11.tap does not have valid IDCODE (idcode=0x1fffc000)
Info : TAP auto12.tap does not have valid IDCODE (idcode=0xfffe000)
Info : TAP auto13.tap does not have valid IDCODE (idcode=0x7fff000)
Info : TAP auto14.tap does not have valid IDCODE (idcode=0x3fff800)
Info : TAP auto15.tap does not have valid IDCODE (idcode=0x1fffc00)
Info : TAP auto16.tap does not have valid IDCODE (idcode=0xfffe00)
Info : TAP auto17.tap does not have valid IDCODE (idcode=0x7fff00)
Info : TAP auto18.tap does not have valid IDCODE (idcode=0x3fff80)
Warn : Unexpected idcode after end of chain: 21 0x001fffc0
Warn : Unexpected idcode after end of chain: 53 0x00000000
Warn : Unexpected idcode after end of chain: 85 0x00000000
Warn : Unexpected idcode after end of chain: 117 0x00000000
Warn : Unexpected idcode after end of chain: 149 0x00000000
Warn : Unexpected idcode after end of chain: 181 0x07fff800
Warn : Unexpected idcode after end of chain: 213 0x00000000
Warn : Unexpected idcode after end of chain: 245 0x00000000
Warn : Unexpected idcode after end of chain: 277 0x00000000
Warn : Unexpected idcode after end of chain: 309 0x00000000
Warn : Unexpected idcode after end of chain: 341 0xffff0000
Warn : Unexpected idcode after end of chain: 373 0x00000000
Warn : Unexpected idcode after end of chain: 405 0x00000000
Warn : Unexpected idcode after end of chain: 437 0x00000000
Warn : Unexpected idcode after end of chain: 469 0x00000000
Warn : Unexpected idcode after end of chain: 501 0xffe00000
Warn : Unexpected idcode after end of chain: 533 0x0000001f
Warn : Unexpected idcode after end of chain: 565 0x00000000
Warn : Unexpected idcode after end of chain: 597 0x00000000
Warn : Unexpected idcode after end of chain: 629 0x00000000
Tried both SD MMC and SPI interfaces. Same story. The function "sdcard_mount_mmc" itself:
static void sdcard_mount_finish(esp_err_t err) {
    if (err == ESP_OK) {
        ESP_LOGI(TAG, "SD card mounted at %s", sdcard_mount_point);
        sdmmc_card_print_info(stdout, m_card);
        /* Print free memory size info */
        printf("Free: %lluMB\n", sdcard_get_free_bytes() / (1 << 20));
        ESP_LOGW(TAG, "sdcard_mount failed (%s)",
                esp_err_to_name(err));
 * Initialize and mount the SD card with MMC interface
 * @return err code
esp_err_t sdcard_mount_mmc() {
    ESP_LOGI(TAG, "Mounting SD MMC...");
	esp_vfs_fat_sdmmc_mount_config_t mount_config = SDCARD_MOUNT_CONFIG_DEFAULT();
    sdmmc_host_t host = SDMMC_HOST_DEFAULT();
    host.max_freq_khz = SDMMC_FREQ_HIGHSPEED;
    // This initializes the slot without card detect (CD) and write protect (WP) signals.
    // Modify slot_config.gpio_cd and slot_config.gpio_wp if your board has these signals.
    sdmmc_slot_config_t slot_config = SDMMC_SLOT_CONFIG_DEFAULT();
    // Use 1-line SD mode
    slot_config.width = 1;
    // Enable internal pullups on enabled pins. The internal pullups
    // are insufficient however, please make sure 10k external pullups are
    // connected on the bus. This is for debug / example purpose only.
    slot_config.flags |= SDMMC_SLOT_FLAG_INTERNAL_PULLUP;
    esp_err_t err = esp_vfs_fat_sdmmc_mount(sdcard_mount_point, &host,
            &slot_config, &mount_config, &m_card);
    sdcard_mount_finish(err);
	return err;
Adding other blocks of code, I2C stuff, WiFI, etc. seem to have no effect on openocd (it does not get broken). Only SD card matters.
Any clues?
TTGO T8's internal SD card slot I'm using:
dizcza
Re: ESP-Prog sdcard issues
Postby dizcza » Mon Nov 14, 2022 3:03 pm
I should have looked at the schematics better. SD card pins reuse JTAG, that's the culprit.
And I think it's impossible to reuse JTAG pins in the app, is it?
