Low-latency (<7ms) audio streaming with ESP-NOW
map_93
Postby map_93 » Wed Nov 16, 2022 10:57 am
Hello everyone,
I am new to the ESP32 world. I am trying to develop a battery operated audio wireless transmission system for musical instruments.
The basic requirements are:
Sample rate: 48kHz
Resolution: 16bit or 24bit
Mono/Stereo: Stereo
I was planning on using ESP-NOW for communication between two EPS32s. My initial tests with ESP-NOW have been underwhelming though. With a basic Arduino sketch example, sending 250 bytes with acknowledge requires 4-5ms on average, with peaks of 10-12ms. I was looking into ESP-IDF for more customisation/better performance, but I got lost in the number of options and settings.
Can anyone confirm if what I am trying to achieve is even possible? Is it normal for sending times to vary so much?
As mentioned, I would like to keep latency low (ideally less than 7ms) as the system is meant for live in-ear monitoring.
Thank you very much for any help/advice!
Users browsing this forum: Amazon [Bot], meta-externalagent, PerplexityBot, PetalBot and 11 guests
