Only one touch pin (T6) not working...........
Zeni241
Postby Zeni241 » Fri Nov 18, 2022 6:04 am
I have loaded touch example “touch_pad_read” on two PCBs with ESP32-WROOM32-UE module.‎
On one PCB everything is OK, but on second PCB touch PAD 6 (PIN 14, T6) is reading 0‎ all the time. ‎? I ‎checked if PIN 14 is connected to ground plane mistakenly, but found out this is not the case. ‎Any guess ‎what could be the problem on second PCB? Is it possible that only one touch pin of module is not ‎working, or is it some configuration problem etc? ‎
I am using ESP-IDF V4.4.2.‎
Reading on PCB1 which is OK:‎
T0:[1605,1605] T1:[1101,1102] T2:[1571,1571] T3:[1558,1558] T4:[1686,1686] T5:[1677,1677] T6:[1762,1762] T7:[1781,1781] ‎T8:[1823,1820] T9:[1871,1867] ‎
T0:[1606,1606] T1:[1103,1103] T2:[1571,1571] T3:[1558,1558] T4:[1686,1686] T5:[1678,1678] T6:[1761,1762] T7:[1781,1781] ‎T8:[1822,1816] T9:[1869,1865] ‎
T0:[1605,1605] T1:[1102,1103] T2:[1571,1571] T3:[1557,1557] T4:[1686,1686] T5:[1677,1677] T6:[1761,1761] T7:[1780,1780] ‎T8:[1810,1816] T9:[1868,1867] ‎
T0:[1606,1606] T1:[1103,1103] T2:[1571,1571] T3:[1558,1558] T4:[1686,1686] T5:[1678,1678] T6:[1761,1761] T7:[1781,1781] ‎T8:[1822,1816] T9:[1851,1860] ‎
T0:[1606,1605] T1:[1103,1102] T2:[1571,1571] T3:[1558,1558] T4:[1686,1686] T5:[1677,1677] T6:[1762,1762] T7:[1781,1780] ‎T8:[1822,1814] T9:[1871,1862]‎
Reading on PCB2, reading 0 in T6:‎
T0:[1605,1605] T1:[1101,1102] T2:[1571,1571] T3:[1558,1558] T4:[1686,1686] T5:[1677,1677] T6:[0,0] T7:[1781,1781] ‎T8:[1823,1820] ‎T9:[1871,1867] ‎
T0:[1606,1606] T1:[1103,1103] T2:[1571,1571] T3:[1558,1558] T4:[1686,1686] T5:[1678,1678] T6:[0,0] T7:[1781,1781] ‎T8:[1822,1816] ‎T9:[1869,1865] ‎
T0:[1605,1605] T1:[1102,1103] T2:[1571,1571] T3:[1557,1557] T4:[1686,1686] T5:[1677,1677] T6:[0,0] T7:[1780,1780] ‎T8:[1810,1816] ‎T9:[1868,1867] ‎
T0:[1606,1606] T1:[1103,1103] T2:[1571,1571] T3:[1558,1558] T4:[1686,1686] T5:[1678,1678] T6:[0,0] T7:[1781,1781] ‎T8:[1822,1816] ‎T9:[1851,1860] ‎
T0:[1606,1605] T1:[1103,1102] T2:[1571,1571] T3:[1558,1558] T4:[1686,1686] T5:[1677,1677] T6:[0,0] T7:[1781,1780] ‎T8:[1822,1814] ‎T9:[1871,1862]‎
Users browsing this forum: Amazon [Bot] and 2 guests
