How to add soil moisture device in esp rainmaker
dr.rajarewatkar
Please help me in adding soil moisture sensor to esp rainmaker.
Re: How to add soil moisture device in esp rainmaker
You can add any custom device and params in RainMaker as you can see here. Just create a device with some name and type (even NULL type is fine since soil moisture sensor anyways is not a standard RainMaker type) and add integer/float/boolean/string parameters to it as per your requirement.
