How to resolve conflicting component names
szabiaura
Postby szabiaura » Thu Nov 24, 2022 10:34 pm
I have a component in my project called button. It uses the button component from the registry. When I try to build, I get this error:
  ERROR: Cannot process component requirements.  Multiple candidates to
  satisfy project requirements:
    requirement: "button" candidates: "espressif__button, button"
How can I specify that I want the button component from the project, not the one from the registry?
Thanks,
Szabi
ESP_kumekay
Re: How to resolve conflicting component names
Postby ESP_kumekay » Mon Feb 20, 2023 1:41 pm
Hello, Szabi, thank you for the question.
Usually, this problem happens if you have
EXTRA_COMPONENT_DIRS
set in your project. Dependencies in EXTRA_COMPONENT_DIRS have the same priority as ones installed with the component manager.
To solve it you can either remove the dependency from idf_component.yml manifest or move your local component to the "components" directory in your project.
Related GitHub issue: https://github.com/espressif/idf-compon ... /issues/25
