how continuous A2D with lowest power
davidbeccue
Postby davidbeccue » Fri Nov 25, 2022 9:21 pm
I want to gather continuous ADC data at 256hz (with timing errors < 0.01%). Every second or so I want to write that to external flash and do some other high level processing. What is the best way to do this?
I'm guessing that I keep the ULP running constantly looking for an external 256hz clock tick on a GPIO. And then gather the data into RTC Ram, and wakeup the main core every second to move that data into flash. If so, then I wonder if there is a limit to the write cycles for RTC Ram. And secondly, should I worry about not using a semaphore to ensure the ULP and main core aren't writing and reading simultaneously? Or should I try to halt the ULP between ADC sampling to save power?
The bottom line is to ask, what is the best way to do this?
Thanks, David
Users browsing this forum: Bing [Bot], Google [Bot], Semrush [Bot] and 4 guests
