ESP32-C3-MINI-1 error flashing firmware
eldadcicc
Postby eldadcicc » Sat Nov 26, 2022 6:44 pm
Hi
I am facing the same problem like others here.
I designed 2 different PCBA for ESP32-C3-MINI-1.
You can see in the attached files.
Both designed have the same problem.
When I am connecting the boards to a PC via the USB connection - it connect - disconnect all the time. i.e. not stable USB connection and each time the "USB Vendor name is different" so it is not stable and I can't flash firmware.
When I am using external USB 2 TTL device - the USB is stable but the data from the RX TX is "invalid header: 0xffffffff" and restart every several seconds. I was trying everything - but it is impossible to upload firmware.
I also connected development board to the PC via USB 2 TTL device and didn't succeed to flash firmware from the eclipse.
When connecting development module via the USB to the PC everything is working well.
Please help me to solve this issue.
Schematics_updated.pdf
2nd design
(385.76 KiB) Downloaded 254 times
PCBLayout.pdf
1st design
(61.42 KiB) Downloaded 254 times
Schematics.pdf
1st design
(24.46 KiB) Downloaded 238 times
Users browsing this forum: Baidu [Spider], ChatGPT-User, coccocbot, meta-externalagent and 2 guests
