ESP32-S3作为STA无法同时UDP广播发送和接收
birdlf
Postby birdlf » Mon Nov 28, 2022 1:21 am
请教各位大佬,我的项目是100多台分布设备,都采用ESP32-S3作为STA,然后他们之间通过UDP广播来无线通讯。
但是我参照《ESP32-C3物联网工程开发实战》里面的“broadcast_discovery”项目例程来改造的程序,接收和发送都保持同一个端口。却总是发送和接收不能同时存在。一旦先发送了,就再也接收不到广播了。而相反,如果先接收了数据,就不能再发送了。
请教各位,我应该怎么做,才能做到同时收发UDP广播呀?有什么方法能类似以前用AT指令的时候那样,设置多链接,然后用两个链接分别配置接收和发送呀?(AT+CIPSTART=0,"UDP","192.168.6.111",6000,3333 AT+CIPSTART=1,"UDP","255.255.255.255",3333,6000)
谢谢大家!
代码如下:
static esp_err_t esp_send_broadcast( uint8_t *sendBuf, uint8_t len )
int opt_val = 1;
esp_err_t err = ESP_FAIL;
struct sockaddr_in from_addr = {0};
socklen_t from_addr_len = sizeof(struct sockaddr_in);
char udp_recv_buf[64 + 1] = {0};
// 创建 IPv4 UDP 套接字
int sockfd = socket(AF_INET, SOCK_DGRAM, 0);
if (sockfd == -1) {
return err;
// 设置 SO_BROADCAST 套接字选项, 使能该套接字支持广播发送
int ret = setsockopt(sockfd, SOL_SOCKET, SO_BROADCAST, &opt_val, sizeof(int));
if (ret < 0) {
goto exit;
// 设置广播目的地址和端口
struct sockaddr_in dest_addr = {
.sin_family = AF_INET,
.sin_port = htons(3333),
.sin_addr.s_addr = htonl(INADDR_BROADCAST),
// 调用 sendto 接口发送广播数据
ret = sendto(sockfd, sendBuf, len, 0, (struct sockaddr *)&dest_addr, sizeof(struct sockaddr));
exit:
close(sockfd);
return err;
void app_main(void)
uartInit();
uint8_t udp_server_buf[64 + 1] = {0};
char *udp_server_send_buf = "ESP32-C3 Smart Light https 443";
int sockfd = 0;//IPv4 UDP 套接字
int ret = 0;
// 设置广播目的地址和端口
struct sockaddr_in server_addr = {
.sin_port = htons(6000),
.sin_addr.s_addr = htonl(INADDR_ANY),
while(1)
// 调用 recvfrom 接口接收广播数据
ret = recvfrom(sockfd, udp_server_buf, sizeof(udp_server_buf) - 1, 0, (struct sockaddr *)&from_addr, (socklen_t *)&from_addr_len);
if (ret > 0)
uartSend(udp_server_buf, ret);
int res = uartReadData();
if(res == 1)//连接WIFI
//Initialize NVS
ESP_ERROR_CHECK(ret);
ESP_LOGI(TAG, "ESP_WIFI_MODE_STA");
int a = wifi_init_sta();
if(a == 1)
uint8_t buf[3] = {01,02,03};
uartSend(buf, sizeof(buf));
//ret = esp_send_broadcast_Init();
else
uint8_t buf[3] = {01,03,04};
else if(res == 2)//建立UDP服务
//uint8_t buf[3] = {03,03,06};
//uartSend(buf, sizeof(buf));
// 创建 IPv4 UDP 套接字
if (sockfd == -1)
uartSendData("socket error!");
ret = bind(sockfd, (struct sockaddr *)&server_addr, sizeof(server_addr));
if (ret < 0) {
uartSendData("bind error!");
close(sockfd);
else if(res == 5)//配置UDP发送套接字
if(!ret)
else
uint8_t buf[3] = {03,04,07};
else if(res == 3)//test
uint8_t buf[9] = {8,8,6,6,7,6,6,8,8};
esp_send_broadcast(buf, 9);
else if(res == 4)//test2
uint8_t buf[10] = {1,2,3,4,5,6,7,8,9,0};
esp_send_broadcast(buf, 10);
else if(res == 6)//正常命令
esp_send_broadcast(uartRXBuf, uartRXBufLen);
YJM
Re: ESP32-S3作为STA无法同时UDP广播发送和接收
Postby YJM » Tue Nov 29, 2022 3:15 am
static esp_err_t esp_send_and_recv_broadcast(void)
   int opt_val = 1;
   // 创建 IPv4 UDP 套接字
   if (sockfd == -1) {
      ESP_LOGE(TAG, "Create UDP socket fail");
      return err;
    // 设置广播接收地址和端口
      .sin_port        = htons(4444),
   int ret = bind(sockfd, (struct sockaddr *)&server_addr, sizeof(server_addr));
   if (ret < 0) {
      ESP_LOGE(TAG, "Bind socket fail");
      goto exit;
   if (ret < 0) {
      ESP_LOGE(TAG, "Set SO_BROADCAST option fail");
      goto exit;
   // 设置广播发送地址和端口
   char *broadcast_msg_buf = "Are you Espressif IOT Smart Light";
   ret = sendto(sockfd, broadcast_msg_buf, strlen(broadcast_msg_buf), 0, (struct sockaddr *)&dest_addr, sizeof(struct sockaddr));
   if (ret < 0) {
      ESP_LOGE(TAG, "Error occurred during sending: errno %d", errno);
      ESP_LOGI(TAG, "Message sent successfully");
      ret = recvfrom(sockfd, udp_recv_buf, sizeof(udp_recv_buf) - 1, 0, (struct sockaddr *)&from_addr, (socklen_t *)&from_addr_len);
      if (ret > 0) {
         ESP_LOGI(TAG, "Receive udp unicast from %s:%d, data is %s", inet_ntoa(((struct sockaddr_in *)&from_addr)->sin_addr), ntohs(((struct sockaddr_in *)&from_addr)->sin_port), udp_recv_buf);
         err = ESP_OK;
exit:
   close(sockfd);
   return err;
一个 socket 就能搞定了,发送的目的端口是 3333,接收的端口是 4444。
shufeng1911
Postby shufeng1911 » Thu Aug 08, 2024 6:52 am
这个问题有解决吗?
Users browsing this forum: Bing [Bot] and 2 guests
