Arduino ESP32 Framework V2.0.5 Changes TWAI Errata Config Options?
CraftyMyner
Postby CraftyMyner » Mon Dec 05, 2022 12:11 pm
Hello, I have had issues with a few devices failing to recover from bus off state. I located the cause to be the absence of CONFIG_TWAI_ERRATA_FIX_BUS_OFF_REC set in the Arduino framework. I spent quite a bit of time converting over to ESP-IDF to allow the extra flexibility of setting various sdkconfig (tools/sdk/esp32/sdkconfig) options. I copied the latest arduino sdkconfig to get started but when I went to change the TWAI errata options I found they were already set. I thought I was losing my mind as I had checked before and they were not set. I went back through the commits and found "ESP-IDF v4.4.2 and build time elf2bin for the bootloaders (#7259)".
I see that 4 errata fixes were enabled in that commit without any mention of them in release notes or issues. I am happy they are changed, I think it's the right thing, however, I have some questions.
1. Was there a particular reason these were just set now in this commit?
2. Are these options going to stay set, can I rely on them or is they going to change in the future.
3. Is there a way that I can verify these options are set at compile time to warn me incase I miss checking the source of each update.
Thanks!
The sdkconfig commit in question: https://github.com/espressif/arduino-es ... d333cd4bb7
# TWAI configuration
# CONFIG_TWAI_ISR_IN_IRAM is not set
CONFIG_TWAI_ERRATA_FIX_BUS_OFF_REC=y
CONFIG_TWAI_ERRATA_FIX_TX_INTR_LOST=y
CONFIG_TWAI_ERRATA_FIX_RX_FRAME_INVALID=y
CONFIG_TWAI_ERRATA_FIX_RX_FIFO_CORRUPT=y
# end of TWAI configuration
Users browsing this forum: Barkrowler, PerplexityBot and 1 guest
