ESPNOW and WIFI channels
davnec
Postby davnec » Tue Dec 06, 2022 10:04 am
Hi at all, I'm sorry to repropose this argument that already discussed in this formum, but I don't found a clear solutio (if exists..)
I'm working on refactoring of an old firmware that connect two device
First connected to WIFI and communicate via ESP-Now with second remote device.
The main problem is that the AP can change the wifi channel dinamically and consequently the esp-now channel.
The remote device cannot have access to wifi.
The old firmware use a trik to solve this problem
- The remote listens on the channel 1
- The master set the wifi channel to 1 with
esp_wifi_set_channel(0x01, WIFI_SECOND_CHAN_NONE);
- The master send a message containing the real wifi channel and then change again the channel to the real wifi
- The remote send the response on the real wifi channel
I know that it's a little devilish, but works on the old IDF (I don't know the exact version)
but on the new version (actual release 5.0) i have the message
wifi:STA is scanning or connecting, or AP has connected with external STAs, cannot set channel
I read a lot of post, but I did not find it clearly written if there is a workaround to solve this issue.
Thanks a lot
Davide
Users browsing this forum: Amazon [Bot] and 1 guest
