ESP32S3 Applying voltage on ADC pin of unpowered chip
rtborg
Postby rtborg » Mon Dec 12, 2022 2:45 pm
What would be the outcome of applying voltage (3.3V) to the analog input pin of an unpowered chip?
My case is that a user may connect a sensor output to chip's analog input before powering on the chip itself.
Re: ESP32S3 Applying voltage on ADC pin of unpowered chip
Postby Sprite » Tue Dec 13, 2022 1:05 am
The ESD protection inside the chip would probably shunt that voltage to the 3.3V rail. That's probably not a super-big deal if the sensor is current-limited. If it is not, you'd effectively be trying to power the system through a GPIO, and I'm not sure if that poor ESD protection thing is able to handle that.
