Antenna design
rkumararora
Antenna design
Hi Iam using ESP32 controller, and I want to design the antenna on my PCB board, Can I get the antenna design details?
Re: Antenna design
Here you can find a similar thread:Hi Iam using ESP32 controller, and I want to design the antenna on my PCB board, Can I get the antenna design details?
viewtopic.php?t=8050
I do not like PCB antennas at all personally, specially because for it to make sense at all, you'd need proper impedance control of your PCB in production, which is not cheap. Specially for lower amounts, it's not really worth it then. But you should find hints and answers in the mentioned thread ^^
rkumararora
Re: Antenna design
the antenna dimensions given in the link you shared for github is different than the anntenna dimension of ESP32 WROOM module gerber.
Please provide clarification.
