Minimum ESP32 circuit required for runtime
WoolySheep
Postby WoolySheep » Sun Dec 18, 2022 7:30 pm
Hi all,
I normally use an 'ESP32 Dev Kit C' for my projects. This time I want to create a PCB and solder an ESP32-Wroom-32D chip direct to it. This will make my project much smaller.
So, I have bought 5 of the below:
Then, I made the below circuit as I think it is the most basic that I need to be able to upload code.
The USB TTL Interface has a built-in AMS1117 3.3v regulator in it.
Can people please tell me if the above circuit will work.
Many thanks
Alan
Re: Minimum ESP32 circuit required for runtime
Postby Sprite » Mon Dec 19, 2022 2:03 am
You need at least a power-on reset RC network on your EN pin. Given that you have an 10K pullup already, simply add an 1uF between ground and EN and that should be fixed.
WoolySheep
Postby WoolySheep » Mon Dec 19, 2022 7:53 am
Hi @ESP_Sprite, thank you for your help. So, how is the below now?
Many thanks
Alan
Users browsing this forum: Baidu [Spider], PerplexityBot, Semrush [Bot] and 2 guests
