what's mean about UART_PIN_NO_CHANGE?
is it to say PIN not use,connect to no phy pin?
UART_PIN_NO_CHANGE
Re: UART_PIN_NO_CHANGE
Esssentially, it means that the UART code should not touch any of the settings for that signal. If the signal already is routed to a pin in some fashion (e.g. by having manually tweaked the GPIO mux beforehand), it will stay there; if the signal is unconnected it will stay unconnected. Unless you specifically have code that acts on the signal beforehand, you can interpret this as 'do not connect'.
Users browsing this forum: Baidu [Spider], ChatGPT-User, PerplexityBot and 3 guests
