ESP-ADF的某个模块(JSMN)无法下载,编译报错
Yobby0908
Postby Yobby0908 » Sat Jan 07, 2023 4:28 am
---------------------------ERROR--------------------------
[0;33mHINT: The component jsmn has been moved to the IDF component manager or has been removed and refactored into some other component.
Please look out for component in 'https://components.espressif.com' and add using 'idf.py add-dependency' command.
Refer to the migration guide for more details.[0m
-----------------------END OF ERROR-----------------------
显示jsnm已经没有了,请问如何解决这个问题?
我尝试了添加,但是不知道要添加到哪里?
William
Re: ESP-ADF的某个模块(JSMN)无法下载,编译报错
Postby William » Mon Feb 06, 2023 8:57 am
可以重新更新一下 ESP- ADF,submodule
另外请问您使用的 IDF 版本是 ADF 里面默认的么,还是?
Users browsing this forum: YisouSpider and 1 guest
