Has anyone else experienced this?
Code: Untitled.c Select all
/* Hello World Example
#include <stdio.h>
#include "sdkconfig.h"
#include "freertos/task.h"
#include "esp_system.h"
#include "esp_spi_flash.h"
#include <driver/gpio.h>
/* Private defines -----------------------------------------------------------*/
#define CNVST_PIN 14 /* Conversion start control. */
/* Function Definitions ------------------------------------------------------*/
void IRAM_ATTR hw_gpio_toggle(void)
uint32_t reg_val = (1ULL << CNVST_PIN);
do {
REG_WRITE(GPIO_OUT_W1TS_REG, reg_val);
REG_WRITE(GPIO_OUT_W1TC_REG, reg_val);
} while (1);
static void hw_gpio_init(void)
gpio_config_t io_conf = {};
uint32_t reg_val;
/* Configure GPIO pin output level - LOW */
io_conf.intr_type = GPIO_INTR_DISABLE;
io_conf.mode = GPIO_MODE_OUTPUT;
io_conf.pin_bit_mask = (1ULL << CNVST_PIN);
io_conf.pull_down_en = 1;
io_conf.pull_up_en = 0;
ESP_ERROR_CHECK(gpio_config(&io_conf));
void app_main(void)
uint16_t recvbuf;
printf("Hello world!\n");
/* Print chip information */
esp_chip_info_t chip_info;
esp_chip_info(&chip_info);
printf("This is %s chip with %d CPU core(s), WiFi%s%s, ",
CONFIG_IDF_TARGET,
chip_info.cores,
(chip_info.features & CHIP_FEATURE_BT) ? "/BT" : "",
(chip_info.features & CHIP_FEATURE_BLE) ? "/BLE" : "");
printf("silicon revision %d, ", chip_info.revision);
printf("%dMB %s flash\n", spi_flash_get_chip_size() / (1024 * 1024),
(chip_info.features & CHIP_FEATURE_EMB_FLASH) ? "embedded" : "external");
printf("Minimum free heap size: %d bytes\n", esp_get_minimum_free_heap_size());
hw_gpio_init();
for (;;) {
hw_gpio_toggle();
