Using memory register to disable ROM messages out UART0 doesn't work
MikeMyhre
Postby MikeMyhre » Fri Jan 13, 2023 9:31 pm
IDF Version 4.4.3-dirty
Product: ESP32-s3-wroom
Problem: Unable to disable ROM Log to UART 0 using register address.
Expected Test Result: ROM messages should stop being printed out UART0 after the CNTL_STORE4 register bit is set. Messages should still be printed out USB. The register overrides both the EFuse and GPIO settings.
Actual Result: ROM Messages continue to be printed over UART 0
Steps to reproduce:
Step 1: Start new project with the following code:
#define RRTAG "RESET_REASON"
void app_main(void)
	configure_led();
	switch( esp_reset_reason() ) {
    case ESP_RST_DEEPSLEEP:
    	ESP_LOGI(RRTAG,"DEEP SLEEP");
    case ESP_RST_WDT:
    	ESP_LOGI(RRTAG,"WDT");
    case ESP_RST_TASK_WDT:
    	ESP_LOGI(RRTAG,"Task WDT");
    case ESP_RST_INT_WDT:
    	ESP_LOGI(RRTAG,"INT WDT");
    case ESP_RST_PANIC:
    	ESP_LOGI(RRTAG,"PANIC");
    case ESP_RST_POWERON:
    	ESP_LOGI(RRTAG,"POWERON");
    	boot_count = 0;
    case ESP_RST_UNKNOWN:
    	ESP_LOGI(RRTAG,"Unknown");
    case ESP_RST_SW:
    	ESP_LOGI(RRTAG,"Software");
    default:
    	ESP_LOGI(RRTAG,"Code: %d",esp_reset_reason());
	boot_count++;
    ESP_LOGI("boot", "Boot count: %d", boot_count);
    if( boot_count == 1 ) {
    	esp_sleep_pd_config(ESP_PD_DOMAIN_RTC_SLOW_MEM, ESP_PD_OPTION_ON);
    	esp_sleep_pd_config(ESP_PD_DOMAIN_RTC_FAST_MEM, ESP_PD_OPTION_ON);
    	uint32_t val = REG_SET_BIT(RTC_CNTL_STORE4_REG, RTC_DISABLE_ROM_LOG);
    	ESP_LOGI("ROM_LOG","CNTL_STORE4_REG: 0x%04X - 0x%X",RTC_CNTL_STORE4_REG,val);
    	printf("Restarting and preserving RTC\n");
    	esp_restart();
	printf("Start of main\n");
    while( 1 ) {
        vTaskDelay( pdMS_TO_TICKS(1000) );
        printf("Log Message\n");
Step 2: View data on UART0 which should be silent after the REG_SET_BIT(...) command.
As described in technical manual table 8-3:
