Which board type to choose for ESP32-DevKitC-VE ?
espmoses
Postby espmoses » Sun Jan 15, 2023 9:43 pm
Hello Everyone,
I have several original ESP32-DevKitC-VE boards. I am wondering which particular "board" I should be selecting in the Arduino IDE ?
I've used Node32s initially, and although it was working fine, I didn't have all the options I should have had in the tools menu. I believe after an upgrade I have both "ESP32 Wrover Module" and "ESP32 Wrover Kit (all versions)".
Two main question arise..
Is there a preferred or recommended board type to use for the factory ESP32-DevKitC-VE boards ?
And if both work.. other then not being able to select certain options, is there anything wrong with using one or the other?
Thank you for your time!
Regards,
-Moses
Users browsing this forum: Semrush [Bot] and 3 guests
