Won't reboot after spurious crash. "W (32) rtc_clk: Bogus XTAL frequency: 0 MHz"
novalight
Postby novalight » Thu Sep 28, 2017 10:20 am
Hey, I've noticed recently some strange behavior: (I am using a custom board with 40MHz and 32kHz crystals, this is also set in sdkconfig)
1. The ESP32 crashes because of a "StoreProhibited", caused by _gettimeofday_r . I call gettimeofday in an if-branch that should never be entered in the given application.
2. It reboots and outputs:
ets Jun  8 2016 00:22:57
rst:0xc (SW_CPU_RESET),boot:0x17 (SPI_FAST_FLASH_BOOT)
configsip: 0, SPIWP:0xee
mode:DIO, clock div:1
load:0x3fff0010,len:4
load:0x3fff0014,len:7772
load:0x40078000,len:0
load:0x40078000,len:13760
entry 0x40079384
3. The debug output contiues then on UART1:
I (730) cpu_start: Pro cpu up.
I (733) cpu_start: Starting app cpu, entry point is 0x40080f8c
I (740) cpu_start: App cpu up.
I (744) heap_init: Initializing. RAM available for dynamic allocation:
I (751) heap_init: At 3FFAE6E0 len 00001920 (6 KiB): DRAM
I (757) heap_init: At 3FFBAB60 len 000254A0 (149 KiB): DRAM
I (763) heap_init: At 3FFE0440 len 00003BC0 (14 KiB): D/IRAM
I (770) heap_init: At 3FFE4350 len 0001BCB0 (111 KiB): D/IRAM
I (776) heap_init: At 40091000 len 0000F000 (60 KiB): IRAM
I (782) cpu_start: Pro cpu start user code
>>>>Log ends here, application is not executed<<<<
Probably an interesting side note: When de device boots in normal state it says:
rst:0x1 (POWERON_RESET),boot:0x17 (SPI_FAST_FLASH_BOOT)
entry 0x40079384
W (32) rtc_clk: Possibly invalid CONFIG_ESP32_XTAL_FREQ setting (40MHz). Detected 40 MHz.
What could be the issue here? Probably some kind of thermal issue? The device is now outside where it gets quite cold at night.
novalight
Re: Won't reboot after spurious crash. "W (32) rtc_clk: Bogus XTAL frequency: 0 MHz"
Postby novalight » Wed Oct 18, 2017 10:05 am
FYI, since this bug looks quite serious to us (it prevents unattended operation of the device basically) I've created an issue on github:
https://github.com/espressif/esp-idf/issues/1132
