web socket client issue.
yehuda
Postby yehuda » Mon Jan 16, 2023 11:11 am
The web socket client example didn't work with web socket server (https://www.piesocket.com/websocket-tester) until we sent header and data at once.
Please see the the current sdk5.0 implementation and our changes below:
Code: Untitled.c Select all
// current SDK code
static int _ws_write(esp_transport_handle_t t, int opcode, int mask_flag, const char *b, int len, int timeout_ms)
transport_ws_t *ws = esp_transport_get_context_data(t);
char *buffer = (char *)b;
char ws_header[MAX_WEBSOCKET_HEADER_SIZE];
char *mask;
int header_len = 0, i;
int poll_write;
if ((poll_write = esp_transport_poll_write(ws->parent, timeout_ms)) <= 0) {
ESP_LOGE(TAG, "Error transport_poll_write");
return poll_write;
ws_header[header_len++] = opcode;
if (len <= 125) {
ws_header[header_len++] = (uint8_t)(len | mask_flag);
} else if (len < 65536) {
ws_header[header_len++] = WS_SIZE16 | mask_flag;
ws_header[header_len++] = (uint8_t)(len >> 8);
ws_header[header_len++] = (uint8_t)(len & 0xFF);
ws_header[header_len++] = WS_SIZE64 | mask_flag;
/* Support maximum 4 bytes length */
ws_header[header_len++] = 0; //(uint8_t)((len >> 56) & 0xFF);
ws_header[header_len++] = 0; //(uint8_t)((len >> 48) & 0xFF);
ws_header[header_len++] = 0; //(uint8_t)((len >> 40) & 0xFF);
ws_header[header_len++] = 0; //(uint8_t)((len >> 32) & 0xFF);
ws_header[header_len++] = (uint8_t)((len >> 24) & 0xFF);
ws_header[header_len++] = (uint8_t)((len >> 16) & 0xFF);
ws_header[header_len++] = (uint8_t)((len >> 8) & 0xFF);
ws_header[header_len++] = (uint8_t)((len >> 0) & 0xFF);
if (mask_flag) {
mask = &ws_header[header_len];
getrandom(ws_header + header_len, 4, 0);
header_len += 4;
for (i = 0; i < len; ++i) {
buffer[i] = (buffer[i] ^ mask[i % 4]);
if (esp_transport_write(ws->parent, ws_header, header_len, timeout_ms) != header_len) {
ESP_LOGE(TAG, "Error write header");
return -1;
if (len == 0) {
return 0;
int ret = esp_transport_write(ws->parent, buffer, len, timeout_ms);
// in case of masked transport we have to revert back to the original data, as ws layer
// does not create its own copy of data to be sent
if (mask_flag) {
mask = &ws_header[header_len-4];
return ret;
// changed code
int poll_write;
char *pData, *pMask = NULL;
char* pBuffer = malloc(len+10); // allocation buffer with length of data plus maximal header length
if(pBuffer == NULL) {
ESP_LOGE(TAG, "Websocket transport: Failed to malloc buffer to sending...");
return 0;
return poll_write;
pBuffer[header_len++] = opcode;
if (len <= 125) {
pBuffer[header_len++] = (uint8_t)(len | mask_flag);
pBuffer[header_len++] = WS_SIZE16 | mask_flag;
pBuffer[header_len++] = (uint8_t)(len >> 8);
pBuffer[header_len++] = (uint8_t)(len & 0xFF);
pBuffer[header_len++] = WS_SIZE64 | mask_flag;
pBuffer[header_len++] = 0; //(uint8_t)((len >> 56) & 0xFF);
pBuffer[header_len++] = 0; //(uint8_t)((len >> 48) & 0xFF);
pBuffer[header_len++] = 0; //(uint8_t)((len >> 40) & 0xFF);
pBuffer[header_len++] = 0; //(uint8_t)((len >> 32) & 0xFF);
pBuffer[header_len++] = (uint8_t)((len >> 24) & 0xFF);
pBuffer[header_len++] = (uint8_t)((len >> 16) & 0xFF);
pBuffer[header_len++] = (uint8_t)((len >> 8) & 0xFF);
pBuffer[header_len++] = (uint8_t)((len >> 0) & 0xFF);
if (mask_flag) {
pMask = &pBuffer[header_len];
getrandom(pMask, 4, 0);
header_len += 4;
pData = &pBuffer[header_len];
memcpy(pData, b, len);
if (mask_flag) {
pData[i] = (pData[i] ^ pMask[i % 4]);
int ret = esp_transport_write(ws->parent, pBuffer, header_len+len, timeout_ms);
free(pBuffer);
return ret;
mi4863
Re: web socket client issue.
Postby mi4863 » Wed Jan 17, 2024 10:57 am
The web socket client example of the esp-idf 5.1.2 didn't work either, if concatenated messages with CONT+FIN are used. In rare cases, already Wireshark misses the FIN part of the message and the unmasked payload looks very strange - like being masked by another mask.
I use the web socket server from https://www.npmjs.com/package/ws. In those rare cases, the server closes the connection with an exception since some of the RSV1/2 bits in the header are 1.
Sending header and data at once solves this issue, however the new implementation has a memory leak if esp_transport_poll_write fails. Some lines have to be exchanged to:
    int poll_write;
        return poll_write;
    char* pBuffer = malloc(len + MAX_WEBSOCKET_HEADER_SIZE);    // allocation buffer with length of data plus maximal header length
    if (pBuffer == NULL) {
        return 0;
Also the memcpy isn't necessary if the data has to be masked, if the masking is done like this:
    if (mask_flag) {
            pData[i] = (b[i] ^ pMask[i % 4]);
I didn't understand why this fix helps, but it does. In Wireshark I see, that now the partial Websocket messages are divided in separate TCP frames and not stacked inside the same TCP frames. This costs perfomance.
Two questions:
Is it planned to include this fix to the released esp-idf?
Is it planned to save the needed the empty FIN message by adding a final flag directly to the last websocket message containing payload? This will reduce the perfomance loss due to this fix.
Bryght-Richard
Postby Bryght-Richard » Wed Nov 20, 2024 6:22 pm
I've also seen small WS frames split over multiple TCP or TLS segments on ESP-IDF v5.1.2, and created https://github.com/espressif/esp-idf/issues/14914 to track it.
I've also had some trouble with the ESP WS transport stability - we have an application-level PING/PONG heartbeat message, and sometimes the ESP's PONG response is delayed after it is split over multiple TLS segments, and the server tears down the connection. I wonder if we need to call esp_transport_poll_write() twice, once before each esp_transport_write()
Bryght-Richard
Postby Bryght-Richard » Fri Dec 06, 2024 4:46 pm
After integrating your fix, it helps a lot, but rarely when sending multiple WS frames close together in time, one will still get stuck in MbedTLS and doesn't reach the TCP send buffer for some times(~10 seconds). Are you using MbedTLS, or WolfSSL, or plaintext(no SSL/TLS)?
Cross-linking related issues:
https://github.com/espressif/esp-idf/issues/14918
https://forums.mbed.com/t/how-can-i-flu ... ayer/24548
Users browsing this forum: Applebot, PetalBot and 6 guests
