When I try to associate the dev board from my iPhone I get this:
␛[0;32mI (1358) app_wifi: Provisioning Started. Name : PROV_67dbc4, POP : 031fc3d8␛[0m
␛[0;32mI (45368) protocomm_nimble: mtu update event; conn_handle=1 cid=4 mtu=185
␛[0m
W (46508) wifi:Error! Should use default active scan time parameter for WiFi scan when Bluetooth is enabled!!!!!!
Guru Meditation Error: Core 0 panic'ed (Instruction access fault). Exception was unhandled.
And the board resets! Help!
Rainmaker resets ESP32-C3--DevKitC-02
sanketwadekar
- Espressif staff
Re: Rainmaker resets ESP32-C3--DevKitC-02
Which example did you try to flash ? Also, did you make any changes to the code ?
