ESP32 Secured Web Server over SSL(WSS)
meakash
Postby meakash » Fri Feb 03, 2023 5:55 am
I am looking for a secure WebSocket Server implementation over SSL for ESP32 using Arduino IDE, so far I haven't been able to find any implementation regarding the same. Please help to get me started with the same.
If there is any Library for the same or how can I use this library to implement the same, i'd be happy to hear any suggestions regarding the same.
daniel_aac
Re: ESP32 Secured Web Server over SSL(WSS)
Postby daniel_aac » Wed Nov 15, 2023 6:09 pm
I have a similar problem, I want to implement an access point (AP) with a server that accepts websocket with encrypted connection (SSL) on an ESP32-S2 chip.
Then libraries used are:
- ESPAsyncWebServer
- ESPAsyncWebSocket
- ESPAsyncTCP
- SPIFFS
but compiling appears the next error class AsyncWebServer has no member named 'beginSecure'.
https://github.com/me-no-dev/ESPAsyncWe ... issues/899
but is for ESP8266,
I'm desperate, I can't find anything online, if anyone can help me I will be forever grateful.
lbernstone
Postby lbernstone » Thu Nov 16, 2023 5:25 pm
It is on the radar for arduino-esp32 to rewrite WebServer to use the underlying IDF libraries, but not high priority. You can try the esp32_https_server which can be found in the arduino library manager, or the IDF https_server is not terribly difficult to use.
Users browsing this forum: Amazon [Bot], ChatGPT-User and 2 guests
