Good Morning,
I am working on a ESP32-S3-WROOM1 N8 module and I would like to know the type of SPI Flash that is embedded in
the module ?
I am wondering if it is NOR Flash, NAN Flash ?
And I am wondering what is the difference between this flash memory and flash memory that we can find in
micro SD Memory Card ?
Thank you for your help,
Best regards,
Thomas TRUILHE
ESP32-S3-WROOM1 : Type of SPI Flash embedded ?
ThomasESP32
Re: ESP32-S3-WROOM1 : Type of SPI Flash embedded ?
Currently, ESP chips can only boot from NOR flash. The difference between it and e.g. a SD card is that SD cards have an entirely different interface, tend to be much larger, and usually consist of NAND flash with an ASIC that acts as a translation layer to do wear leveling and error correction.
ThomasESP32
Thank you for your answer,
and is it possible using librairies to mount a Filesystem on the 8Mo internal NOR Flash ?
Best regards,
Thomas TRUILHE
Best regards,
Thomas TRUILHE
Yes. There's FAT, spiffs and littlefs, for example.
ThomasESP32
Where can i find an example on how to use fatfs in order to mount a filesys on the internan flash. I have done it on an external flash but i dont know the parameters to use for internal flash of the wroom module.
Cpuld you help ?
The same question for the other filsys you mentionned please.
Best regards
Cpuld you help ?
Best regards
The ESP-IDF examples directory tends to have examples for these kinds of things, e.g. a fatfs example would be here.
ThomasESP32
Could y ou confirm that this example can be used with the embedded Flash of the WROOM module ?
Users browsing this forum: Baidu [Spider], ChatGPT-User, Semrush [Bot] and 1 guest
