ESP32-S3-WROOM1 : Type of SPI Flash embedded ?
Posted: Fri Feb 03, 2023 8:11 am
by ThomasESP32
Good Morning,
I am working on a ESP32-S3-WROOM1 N8 module and I would like to know the type of SPI Flash that is embedded in
the module ?
I am wondering if it is NOR Flash, NAN Flash ?
And I am wondering what is the difference between this flash memory and flash memory that we can find in
micro SD Memory Card ?
Thank you for your help,
Best regards,
Thomas TRUILHE
Re: ESP32-S3-WROOM1 : Type of SPI Flash embedded ?
Posted: Fri Feb 03, 2023 1:20 pm
by Sprite
Currently, ESP chips can only boot from NOR flash. The difference between it and e.g. a SD card is that SD cards have an entirely different interface, tend to be much larger, and usually consist of NAND flash with an ASIC that acts as a translation layer to do wear leveling and error correction.
Posted: Fri Feb 03, 2023 3:12 pm
by ThomasESP32
Thank you for your answer,
and is it possible using librairies to mount a Filesystem on the 8Mo internal NOR Flash ?
Best regards,
Thomas TRUILHE
Posted: Sat Feb 04, 2023 12:41 am
by Sprite
Yes. There's FAT, spiffs and littlefs, for example.
Posted: Sat Feb 04, 2023 2:55 pm
by ThomasESP32
Where can i find an example on how to use fatfs in order to mount a filesys on the internan flash. I have done it on an external flash but i dont know the parameters to use for internal flash of the wroom module.
Cpuld you help ?
The same question for the other filsys you mentionned please.
Best regards
Posted: Sun Feb 05, 2023 1:38 am
by Sprite
The ESP-IDF examples directory tends to have examples for these kinds of things, e.g. a fatfs example would be here.
Posted: Mon Feb 06, 2023 5:17 pm
by ThomasESP32
Could y ou confirm that this example can be used with the embedded Flash of the WROOM module ?
