The espressif api-reference shows how to use the can bus peripheral:
https://docs.espressif.com/projects/esp ... s/can.html
However the "driver/can.c", "driver/can.h" and "soc/can_struct.h" files are not actually present in the esp-idf install / master branch.
Where can I find the current version of these files (suitable for the ESP32S3 ?)
can bus driver files
Re: can bus driver files
The docs you're refering to are for ESP-IDF 3.3.5, which is pretty old and which probably isn't the version you're using. You probably want something like this. (Note that the CAN peripheral got renamed to TWAI because of reasons. It's still the same peripheral.)
Thank you.
It would be good if these old docs had a note at the top saying they are old, there's no indication I could see that they are to someone new to ESP. Also a note about the change to TWAI would be great at the top of that page too as it ranks high on a "ESP32 can bus" google search.
Thanks for the response, much appreciated
Users browsing this forum: ChatGPT-User, Qwantbot and 7 guests
