How to suppress sd_diskio message from USB serial output
PeteDD
Postby PeteDD » Mon Feb 06, 2023 8:36 pm
I am using SD card module with ESP32-S3_DEVKIT1. My goal is to check for inserted card. Code is easy enough but when I do the SD.begin(my_SD_CS_pin), when the card is not present, I get a bunch of SDcommand messages from SD_diskio.cpp out the USB serial monitor port. How can I suppress these message (the ones beginning with the bracketed numbers)?
THANKS!
Here is what the serial traffic looks like:
Code: Untitled.cpp Select all
waiting for SD card
[ 3813][W][sd_diskio.cpp:174] sdCommand(): no token received
[ 3915][W][sd_diskio.cpp:174] sdCommand(): no token received
[ 4015][W][sd_diskio.cpp:174] sdCommand(): no token received
[ 4114][E][sd_diskio.cpp:199] sdCommand(): Card Failed! cmd: 0x00
[ 4114][W][sd_diskio.cpp:516] ff_sd_initialize(): GO_IDLE_STATE failed
[ 4115][E][sd_diskio.cpp:802] sdcard_mount(): f_mount failed: (3) The physical drive cannot work
[ 4124][W][sd_diskio.cpp:174] sdCommand(): no token received
waiting for SD card
Found SD Card
SD Card Type: SDHC
SD Card Size: 30543MB
config.ini found.
Here is what my code looks like:
bool CheckForSDCard()
if(!SD.begin(CS_PIN))
bSDCardPresent = false;
return 0;
else
bSDCardPresent = true;
return 1;
void setup()
Serial.println("Hello World!");
while(!CheckForSDCard())
Serial.println("waiting for SD card");
Serial.println("\n\nFound SD Card\n");
// ETC, ETC, ETC
Users browsing this forum: Google [Bot] and 5 guests
