About TLS update (support for DigiCert Global G2 Root) using azure-sdk-for-c-arduino
in order to
below
I would like to know about Azure-SDK-FOR-C-Arduino.
https://github.com/Azure/azure-sdk-for- ... /readme.md
about
and
Sample example
I'm looking at 「 Azure_IoT_Hub_ESP32, 」
What should I do about this?
Unknown.
(Reason: With this program, TLS was updated on February 15, 2023.
Because you are judging. )
Question 1
For the following destination information
What should I apply?
https://techcommunity.microsoft.com/t5/ ... -p/2393169
I would like to test using
What does the following correspond to?
Unknown.
teach me please.
Thing you want to do
Information for the next destination
IoT Hub endpoint: g2cert.azure-devices.net
Connection String: HostName=g2cert.azure-devices.net;DeviceId=TestDevice1;SharedAccessKey=iNULmN6ja++HvY6wXvYW9RQyby0nQYZB+0IUiUPpfec=
Device Provisioning Service (DPS):
Global Service Endpoint: g2-cert-dps.azure-devices-provisioning.net
ID SCOPE: 0ne002B1DF7
Registration ID: abc
Against
What should be applied to what? I want to know
Configure the ESPRESSIF ESP32 sample.
Enter your Azure IoT Hub and device information into the sample's iot_configs.h:
Add you IoTHub Name to IOT_CONFIG_IOTHUB_FQDN
Add your Device ID to IOT_CONFIG_DEVICE_ID
If using X.509 Certs:
Uncomment the #define IOT_CONFIG_USE_X509_CERT
Add your cert to IOT_CONFIG_USE_X509_CERT
Add your cert PK to IOT_CONFIG_DEVICE_CERT_PRIVATE_KEY
If using Symmetric Key:
Add your device key to IOT_CONFIG_DEVICE_KEY
Question 2
for device-to-cloud communication
I want to transfer it as a single character in Char format.
What is the method for that? teach me please.
YN20230201A
Users browsing this forum: Qwantbot and 3 guests
