Hi, I'm trying to get ESP32-S3-DevKitC-1 working with Arudino IDE 2.0.3. Every time with the same error message. Pressing or holding the boot button does not help.
Does anyone have a solution? Thanks!
Output:
Sketch uses 233409 bytes (17%) of program storage space. Maximum is 1310720 bytes.
Global variables use 13152 bytes (4%) of dynamic memory, leaving 314528 bytes for local variables. Maximum is 327680 bytes.
esptool.py v4.2.1
Serial port COM6
Connecting......................................
A fatal error occurred: Failed to connect to ESP32-S3: Invalid head of packet (0x1B): Possible serial noise or corruption.
For troubleshooting steps visit: https://docs.espressif.com/projects/esp ... oting.html
Failed uploading: uploading error: exit status 2
ESP32-S3: Invalid head of packet (0x1B) Arduino IDE 2.0.3
Re: ESP32-S3: Invalid head of packet (0x1B) Arduino IDE 2.0.3
I guess you either gave up or found the solution elsewhere. But, in case someone else comes here looking for the solution, this may be it:
You need to put it in ROM bootloader mode. If you have DFU/boot and reset buttons, hold boot. While holding boot, press and release reset. Then release boot.
