Using esp-camera blocks MCWPM
mcmillanje
Postby mcmillanje » Sat Feb 11, 2023 11:52 pm
I'm trying to use MCWPM to control a servo motor and esp-camera at the same time.
My code is basically a copy of the example here: https://github.com/espressif/esp32-came ... r/examples but I also added in the following function at the top:
[Codebox]static int targetAngle = 0;
static inline uint32_t example_angle_to_compare(int angle)
return (angle - SERVO_MIN_DEGREE) * (SERVO_MAX_PULSEWIDTH_US - SERVO_MIN_PULSEWIDTH_US) / (SERVO_MAX_DEGREE - SERVO_MIN_DEGREE) + SERVO_MIN_PULSEWIDTH_US;
static mcpwm_cmpr_handle_t comparator = NULL;
static mcpwm_gen_handle_t generator = NULL;
static esp_err_t servoInit()
ESP_LOGI(TAG, "Create timer and operator");
mcpwm_timer_handle_t timer = NULL;
mcpwm_timer_config_t timer_config = {
.group_id = 1,
.clk_src = MCPWM_TIMER_CLK_SRC_DEFAULT,
.resolution_hz = SERVO_TIMEBASE_RESOLUTION_HZ,
.period_ticks = SERVO_TIMEBASE_PERIOD,
.count_mode = MCPWM_TIMER_COUNT_MODE_UP,
ESP_ERROR_CHECK(mcpwm_new_timer(&timer_config, &timer));
mcpwm_oper_handle_t oper = NULL;
mcpwm_operator_config_t operator_config = {
.group_id = 1, // operator must be in the same group to the timer
ESP_ERROR_CHECK(mcpwm_new_operator(&operator_config, &oper));
ESP_LOGI(TAG, "Connect timer and operator");
ESP_ERROR_CHECK(mcpwm_operator_connect_timer(oper, timer));
ESP_LOGI(TAG, "Create comparator and generator from the operator");
//mcpwm_cmpr_handle_t comparator = NULL;
mcpwm_comparator_config_t comparator_config = {
.flags.update_cmp_on_tez = true,
ESP_ERROR_CHECK(mcpwm_new_comparator(oper, &comparator_config, &comparator));
//mcpwm_gen_handle_t generator = NULL;
mcpwm_generator_config_t generator_config = {
.gen_gpio_num = SERVO_PULSE_GPIO,
ESP_ERROR_CHECK(mcpwm_new_generator(oper, &generator_config, &generator));
// set the initial compare value, so that the servo will spin to the center position
ESP_ERROR_CHECK(mcpwm_comparator_set_compare_value(comparator, example_angle_to_compare(0)));
ESP_LOGI(TAG, "Set generator action on timer and compare event");
// go high on counter empty
ESP_ERROR_CHECK(mcpwm_generator_set_actions_on_timer_event(generator,
MCPWM_GEN_TIMER_EVENT_ACTION(MCPWM_TIMER_DIRECTION_UP, MCPWM_TIMER_EVENT_EMPTY, MCPWM_GEN_ACTION_HIGH),
MCPWM_GEN_TIMER_EVENT_ACTION_END()));
// go low on compare threshold
ESP_ERROR_CHECK(mcpwm_generator_set_actions_on_compare_event(generator,
MCPWM_GEN_COMPARE_EVENT_ACTION(MCPWM_TIMER_DIRECTION_UP, comparator, MCPWM_GEN_ACTION_LOW),
MCPWM_GEN_COMPARE_EVENT_ACTION_END()));
ESP_LOGI(TAG, "Enable and start timer");
ESP_ERROR_CHECK(mcpwm_timer_enable(timer));
ESP_ERROR_CHECK(mcpwm_timer_start_stop(timer, MCPWM_TIMER_START_NO_STOP));
vTaskDelay(pdMS_TO_TICKS(1000));
return ESP_OK;
}[/Codebox]
and I have a http server running that lets me send commands to the eps32.
My problem is the moment I run
init_camera()
the servo stops working. If I put a vTaskDelay between the servo init and the camera init then the servo will work until the delay runs out and then immediately stop working.
Any Ideas what's happening?
Users browsing this forum: PerplexityBot, Semrush [Bot] and 1 guest
