What TDM audio CODEC can I use?
geedotk
Postby geedotk » Wed Feb 15, 2023 1:41 am
I see in the documenation (https://docs.espressif.com/projects/esp ... s/i2s.html) that the ESP32-S3 has TDM audio support. However, it says, "due to the hardware limitation, only up to 4 slots are supported while the slot is set to 32 bit-width, and 8 slots for 16 bit-width, 16 slots for 8 bit-width." This is 128 bit clocks in one frame, which I have not encountered before. Every CODEC that I know of uses a 256 bit frame with 8 slots of 32 bits, even though they generally use fewer than 32 bits per sample.
Does anyone know of an audio CODEC or a DAC with 8 channels out that can use 16-bit slots?
blowback
Re: What TDM audio CODEC can I use?
Postby blowback » Fri Jun 23, 2023 8:52 pm
I'm facing a similar issue...did you find anything suitable?
siarez
Postby siarez » Mon Jul 07, 2025 11:31 pm
@blowback Did you figure this out? I'm facing the same issue.
blowback
Postby blowback » Mon Oct 20, 2025 7:00 pm
