I'm trying to use ESP32 to modulate throttle response and provide a dashboard for an ebike. I need to read throttle voltage, battery current, do some calculations and output the new voltage, and also read battery level and show speed/RPM from a hall sensor pulse. And I need to make some settings from the throttle adjustable via WIFI (power modes)
Space is very limited and I could not fit an ADC in the project.
Throttle values are 0.9-4.1v, I'm using a voltage divider with two 10k resistors.
Current sensors are 2.5v-4v, R1 and R2 are 10k.
Battery voltages range from 59-86v, R1 is 40k, R2 is 1k.
Hall sensor pulses 3.3v, I'm using a pulldown resistor.
My ADC readings are a complete hell, I get 0 and 4095 readings all the time, so I could not find any way to filter out the noise and get any readable value. (EMA, SMA, median...)
ESP32 is powered with a 5v buck conversor which also powers current sensors, and it is powered by the ebike battery (so a lot of voltage sag when using throttle).
Is there any hope to get ADC readings from internal ADC? If so, should I make any changes in the circuit? Use bigger resistor values? Use a 3.3 voltage regulator on ESP32 Vin?
I really have no clue on what to do and would really appreciate any help provided.
Accurate onboard ADC reading + WiFi // is it even possible?
Re: Accurate onboard ADC reading + WiFi // is it even possible?
That sounds like a very noisy environment indeed. Perhaps some capacitors on the ADC pins can help a bit in cleaning up the signal? (Something like 100nF should be sufficient.) Another trick, especially for slower-moving signals, is to take lots of measures and average them to get rid of the noise.
I tried with a electrolytic between ADC pin and GND and also added another one between VIN and GND, zero results. I've ordered ceramic and they should arrive in two days. (Tomorrow is a national holiday here)That sounds like a very noisy environment indeed. Perhaps some capacitors on the ADC pins can help a bit in cleaning up the signal? (Something like 100nF should be sufficient.)
What does the signal look like on an oscilloscope?
MicroController
Is there any correlation with the actual input signals in the readings at all?I get 0 and 4095 readings all the time
Can you correctly read a fixed voltage (say from a 1.5V battery) on one of the ADC pins to verify that the ADC is correctly configured?
Are you using ADC2? Note these limitations: https://docs.espressif.com/projects/esp ... imitations
