NVS encryption
jonas-vanhoof
NVS encryption
Postby jonas-vanhoof » Tue Feb 21, 2023 1:34 pm
Hello
I can't find good documentation for NVS encryption using arduino framework online.
Using the ESP_IDF framework it should be not that hard. creating those bin's using the idf CLI worked, so that's not the problem, but the code...
If I understand correctly, the Preferences library is used as a wrapper for NVS, but that's not encrypted right? I found some code code snippets online that uses esp-idf framework:
    // 1. find partition with nvs_keys
    const esp_partition_t *partition = esp_partition_find_first(ESP_PARTITION_TYPE_DATA, ESP_PARTITION_SUBTYPE_DATA_NVS_KEYS, "nvs_key");
    if (partition == NULL)
        log_e("Could not locate nvs_key partition. Aborting.");
        return false;
    // 2. read nvs_keys from key partition
    nvs_sec_cfg_t cfg;
    err = nvs_flash_read_security_cfg(partition, &cfg);
    if (err != ESP_OK)
        log_e("Failed to read nvs keys (rc=0x%x)", err);
        return false;
    // 3. initialize nvs partition
    err = nvs_flash_secure_init(&cfg);
    if (err != ESP_OK)
        log_e("failed to initialize nvs partition (err=0x%x). Aborting.", err);
        return false;
    // 4. open nvs partition
    err = nvs_open(name, readOnly ? NVS_READONLY : NVS_READWRITE, &_handle);
    if (err != ESP_OK)
        log_e("nvs_open failed: %s");
        return false;
    _started = true;
    return true;
But the nvs_specific methods (nvs_flash_read_security_cfg eg.) does not seem to work. They give me the error undefined reference to `nvs_flash_read_security_cfg'. It's not clear for me why it does that.
Any help would be nice!
Minatel
Re: NVS encryption
Postby Minatel » Wed Feb 22, 2023 11:57 am
This is not supported by the Arduino ESP32 core.
Users browsing this forum: Google [Bot] and 6 guests
