Bluetooth Serial Class of Device Incorrect and Cannot be Changed
TheTazzi
Postby TheTazzi » Fri Feb 24, 2023 9:13 am
On ESP32 Arduino Core version 2.0.0 and newer, the class of device (COD) for classic bluetooth serial is incorrectly set.
Whereas on v1.0.6, the class of device is set to that of a PC/PDA and also allows changing it inside the BluetoothSerial.cpp file.
The exact same code is run between v1.0.6 and newer, yet the newer versions fail to set the COD and also cannot be changed:
esp_bt_cod_t cod;
cod.major = 0b00001;
cod.minor = 0b000100;
cod.service = 0b00000010110;
if (esp_bt_gap_set_cod(cod, ESP_BT_INIT_COD) != ESP_OK) { log_e("set cod failed"); return false; }
The class of device broadcasted as displayed in Bluetooth Android apps is: 7396 (0x1F00) which is incorrect.
I have wired up a multiple ESP32s which includes multiple ESP-WROOM-32D and also ESP-WROOM-32E, all have the same issue, and all work with v1.0.6 to correctly display the COD
Do note I have had to add disableCore0WDT into the sketch since v2.0.0 and newer sets off the watchdog reset when setting up the bluetooth connection.
Sketch
#include <BluetoothSerial.h>
BluetoothSerial MyBT;
void setup()
        disableCore0WDT();
	MyBT.begin("My BT Name");
void loop()
Debug Message
[ 1485][BluetoothSerial.cpp:263] esp_spp_cb(): ESP_SPP_INIT_EVT
[ 1487][BluetoothSerial.cpp:270] esp_spp_cb(): ESP_SPP_INIT_EVT: slave: start
[ 1492][BluetoothSerial.cpp:397] esp_spp_cb(): ESP_SPP_START_EVT
[ 1496][BluetoothSerial.cpp:685] _init_bt(): device name set
[ 1503][BluetoothSerial.cpp:571] esp_bt_gap_cb(): ESP_BT_GAP_CONFIG_EIR_DATA_EVT: stat:0 num:4
Has anyone else had this issue or found a fix for it?
Minatel
Re: Bluetooth Serial Class of Device Incorrect and Cannot be Changed
Postby Minatel » Fri Feb 24, 2023 5:11 pm
Have you created a new issue on the Arduino ESP32 project on GitHub?
https://github.com/espressif/arduino-esp32/issues
TheTazzi
Postby TheTazzi » Fri Feb 24, 2023 11:00 pm
I sure have: https://github.com/espressif/arduino-esp32/issues/7865
It is still awaiting triage. I was recommended to post on the forums to see if anyone else has noticed the same problems.
Minatel
Postby Minatel » Sat Feb 25, 2023 8:12 pm
We will try to take a look ASAP.
TheTazzi
Postby TheTazzi » Tue Mar 07, 2023 3:35 am
Thanks, please let us know if we can do anything to help!
Users browsing this forum: Baidu [Spider], Bytespider and 2 guests
