dual core programming
aminElmi
Postby aminElmi » Mon Feb 27, 2023 12:28 pm
is there a way in arduino IDE or other IDEs that you run two different tasks with two cores of esp32 but set each core frequency differently for example core 0 is performing its task with 10 Mhz frequency and core1 is doing its task with 80Mhz?
Re: dual core programming
Postby Sprite » Tue Feb 28, 2023 1:14 am
No, sorry, that kind of setup is physically impossible on current ESP chips as the two cores (and the main memory, for that matter) are in the same clock domain.
noweare
Postby noweare » Mon Mar 13, 2023 5:20 pm
You can have two tasks that run at different frequencies on the two different cores. For example two timer tasks.
I am assuming you are not talking about clocking the two cores at different frequencies.
Users browsing this forum: Baidu [Spider] and 2 guests
