I have my own ESP32S3 board which is very simple. It has ESP32-S3-WROOM-1 module with reset circuit and switch, boot switch and a 16p connector to access some pads. Communication with board is via USB Serial/JTAG controller pins 13 and 14 (IO19, IO20)
Strapping pins are left unconnected.
The power is provided by an external supply and my USB cable has only 3 wires D+, D- and GND
Whenever i plug the cable ESP goes through a reboot cycle. Can this reboot be avoided?
Avoid reboot when connecting USB cable
Re: Avoid reboot when connecting USB cable
Please enter into UART0 download mode, then reboot could be stopped. Or if flash is not empty, there should be no reboot.
In general, USB shouldn't do a reboot cycle by itself. What software are you using to look at the serial monitor? Perhaps it wiggles DTR/RTD in such a way that it resets the ESP, 'idf monitor' does that by default iirc.
I agree USB shouldnt do a reboot by simply connecting the cable.
In this case i'm thinking maybe because USB PHY is shared with JTAG logic, some signals have multiple meanings....
I tried with GPIO3 shortcutted to ground to force JTAG signal from on-chip JTAG pins, but same result.
The software i use is teraterm. Looking into settings dowsen't tell anyting about control signals. I tried putty, but same problem.
