Extra component with EN button
BetterWiac
Postby BetterWiac » Tue Mar 14, 2023 12:43 pm
There seems to be an extra component on this devkit (devkit V1 is the only info i have)
I just got this board and haven't worked with any other ESP32 boards before but this component seems out of place. After lookin at videos featuring similar esp32 boards and pictures it seems as though this is a defect.
Should i desolder it or should i keep it there?
The EN button also seems to not be properly aligned with the markings.
Re: Extra component with EN button
Postby Sprite » Wed Mar 15, 2023 12:09 am
That is likely a hacky fix to make the boards auto-download function work with a wider range of PCs/OSses. It lengthens the time the PC has to set IO0 low, which in some cases is needed. If the board otherwise works, I'd leave it in as is.
