I purchased 3 of these units all with an RGB demo on them.
After flashing the demo Blink from the IDF examples, it stopped blinking. Why?
I measured pin 2 of the LED, data in, and it connected to pin 18 (left) which is GPIO 12, not GPIO 18.
Checking one of the other "virgin" boards, pin 2 also goes to pin 18 which is GPIO 12.
All this is derived from the documents from:
https://docs.espressif.com/projects/esp ... itc-1.html
No. Name Type 1 Function
18 12 I/O/T RTC_GPIO12, GPIO12, TOUCH12, ADC2_CH1, FSPICLK, FSPIIO6
Meanwhile in the schematic SCH_ESP32-S2-DEVKITC-1_V1_20220817.pdf and the list above:
11 18 I/O/T RTC_GPIO18, GPIO18, U1RXD, ADC2_CH7, DAC_2, CLK_OUT3, RGB LED
The RGB LED does not connect through R17 to pin 11....
What exactly is going on here with the schematic and document?
How do I correct the RGB LED in the software to point to pin 18 GPIO 12?
Have I lost my mind????
Or how to dump the code from the untouched boards to preserve the blink that cam with
them?
ESP-32S2 Dev/KitC-1 RGB LED
Re: ESP-32S2 Dev/KitC-1 RGB LED
Did you run menuconfig on the blink example and configure the demo for your board ?
Brutas Minimus
If you could explain where or how to do just that, I will try it,
Meanwhile, I found out about esptool and downloaded the firmware from a virgin board ( I bought 3 ) and reflashed the broken board and it ran again.
All of that, I'd still like to know how to do it the proper way.
Assuming you are running Arduino IDE, install the NeoPixel Library from Adafruit and then use something like this:
To dump the existing firmware, assuming you are on Linux (on other OS, replace the "COM Port")..
// Sample code to control the single NeoPixel on the ESP32-S2 Saola (and other S2 boards)
// https://www.instructables.com/ESP32-S2-Saola-Making-the-RGB-Work/
// requires: https://github.com/adafruit/Adafruit_NeoPixel
#include <Adafruit_NeoPixel.h>
// On the ESP32S2 SAOLA, etc. pin 18 is the NeoPixel.
#define PIN 18
// Single NeoPixel
Adafruit_NeoPixel pixels(1, PIN, NEO_GRB + NEO_KHZ800);
uint16_t colourDelay = 10; // Time (in milliseconds) to pause between color change
//This pixel is just way to bright, lower it to 10 so it does not hurt to look at.
pixels.setBrightness(10); // set it to 1 to get traffic light effect
pixels.begin(); // INITIALIZE NeoPixel (REQUIRED)
// Simple function to return a color in the rainbow
// Input a value 0 to 255 to get a color value.
uint32_t Wheel(uint8_t WheelPos)
// Assume the wheel value is less than 85, if so Green value is 0
uint32_t returnColor = Adafruit_NeoPixel::Color((uint8_t)(255 - (WheelPos * 3)), 0, (uint8_t)(WheelPos * 3));
// If we are greater than 170 Red value is 0
if (WheelPos > 84 && WheelPos < 170)
WheelPos -= 85;
returnColor = Adafruit_NeoPixel::Color(0, (uint8_t)(WheelPos * 3), (uint8_t)(255 - WheelPos * 3));
// Finally above 170 and Blue value is 0
else if (WheelPos >= 170)
WheelPos -= 170;
returnColor = Adafruit_NeoPixel::Color((uint8_t)(WheelPos * 3), (uint8_t)(255 - WheelPos * 3), 0);
return returnColor;
// Counter to run from 0-255 to cycle the colors of the rainbow.
int colorCount = 0;
// Set the new color on the pixel.
pixels.setPixelColor(0, Wheel(colorCount++));
// Send the updated pixel colors to the hardware.
pixels.show();
// Cycle the colors at the end.
if (colorCount > 255)
colorCount = 0;
// Pause before next pass through loop
delay(colourDelay);
esptool.py -b 460800 -p /dev/ttyUSB0 read_flash 0x0 0x200000 flash_image.binRe: ESP-32S2 Dev/KitC-1 RGB LED
Could you send boards figures? I check that it is GPIO18 not GPIO12, corresponding to schematic.
