Dear community,
I am currently using ESP-BLE-MESH API to ultimately control a bluetooth mesh light dimmer.
In nRF Mesh app, after inputting the mesh json schema file (available from vendor app), dimmer is visible as a node and its model composition is as follows:
- config server & health server (foundations mandatory models)
- & a vendor model ID 0x0001, CID 0A8B.
I sniffed the opcode messages that dims the light. They are message opcodes 6 with parameter payload ranging from 0 to 100 (0x64).
I can also control this node from nRF app by sending messages, so far so good.
I am trying to implement this on the ESP32 now.
My 2 questions are
- Should I implement the ESP32 acting as a node with a config server and a vendor client model which would publish message opcode 6?
or would I need additional information from the vendor?
- which examples would you use as a starter from the ESP-BLE-MESH repo to achieve this?
Thanks a lot for your help, I cannot wait to control the light remotely thanks to the ESP32.
BLE-MESH ESP-32 Light Dimmer Vendor Model implementation
esp32besbar
esp32besbar
Re: BLE-MESH ESP-32 Light Dimmer Vendor Model implementation
I finally managed !
By
(1) implementing a vendor server model on the ESP32 with understandable OPCODES for the light dimmer
(2) sending (not publishing) messages to the dimmer from the ESP32 with esp_ble_mesh_server_model_send_msg() with right parameters.
It is fantastic. 10 days ago, I knew nothing about ESP-IDF nor coding in C, nor how to read an APi suh as ESP-BLE-MESH.
But by reading materials from Bluetooth website (especially by exercising with mesh study kit proposed by Martin Wooley), & spending hours and hours of reading ESP-BLE-MESH API functions, macro, helper, struct, pointers, etc....., I did an implementation of the Bluetooth mesh.
Time now to code some MQTT protocol so that,
when the ESP32 receives MQTT messages from my Node-Red Server (ultimately to control the dimmer),
it forwards the payload through bluetooth mesh protocol to the dimmer.
We will see if Wifi, bluetooth mesh and MQTT work well together.
By
esp32besbar
Everything is working like a charm (WiFi + MQTT + BT Mesh).
If anyone want to share about models implementations tips and tricks, I would be very interested to discuss with.
Speak to you soon !
Speak to you soon !
schrodinger_smile
Can you share your code? I have currently learned the esp ble mesh node example code with the help of ChatGPT, but I still have many areas where I am not clear. I hope to achieve content similar to your project. Thank you for reading. If possible, thank you for sharing.
esp32besbar
Dear Schrodinger_smile,Can you share your code? I have currently learned the esp ble mesh node example code with the help of ChatGPT, but I still have many areas where I am not clear. I hope to achieve content similar to your project. Thank you for reading. If possible, thank you for sharing.
Just for you to know, I started my project with the vendor server example in ESP BLE MESH. I added also a OnOff Generic server.
I am below copying the code of the main file.
I suggest you read, and if you have further questions, I will make my possible to answer it.
I suggest also, that if you manage, and come by Paris, I am a beer lover.
Last but not least, to make work BLE MESH, wifi together you will need to use a partition table, that is available in the wifi/bluetooth mesh coexist example, also available in BLE MESH repo.
Good luck with your project!
#include <stdio.h>
#include <string.h>
#include <inttypes.h>
#include "esp_log.h"
#include "nvs_flash.h"
#include "esp_ble_mesh_defs.h"
#include "esp_ble_mesh_common_api.h"
#include "esp_ble_mesh_networking_api.h"
#include "esp_ble_mesh_provisioning_api.h"
#include "esp_ble_mesh_config_model_api.h"
#include "esp_ble_mesh_generic_model_api.h"
#include "esp_ble_mesh_local_data_operation_api.h"
#include "board.h"
#include "ble_mesh_example_init.h"
//vendor model library
#include "esp_bt.h"
//wifi librairies
#include "lwip/err.h"
#include "lwip/sys.h"
#include "freertos/task.h"
#include "esp_system.h"
#include "esp_wifi.h"
#include "esp_event.h"
//mqtt
#include "protocol_examples_common.h"
#include "lwip/sockets.h"
#include "lwip/dns.h"
#include "lwip/netdb.h"
#include "mqtt_client.h"
#define EXAMPLE_ESP_WIFI_SSID CONFIG_ESP_WIFI_SSID
#define EXAMPLE_ESP_WIFI_PASS CONFIG_ESP_WIFI_PASSWORD
#define EXAMPLE_ESP_MAXIMUM_RETRY CONFIG_ESP_MAXIMUM_RETRY
#if CONFIG_ESP_WIFI_AUTH_OPEN
#define ESP_WIFI_SCAN_AUTH_MODE_THRESHOLD WIFI_AUTH_OPEN
#elif CONFIG_ESP_WIFI_AUTH_WEP
#define ESP_WIFI_SCAN_AUTH_MODE_THRESHOLD WIFI_AUTH_WEP
#elif CONFIG_ESP_WIFI_AUTH_WPA_PSK
#define ESP_WIFI_SCAN_AUTH_MODE_THRESHOLD WIFI_AUTH_WPA_PSK
#elif CONFIG_ESP_WIFI_AUTH_WPA2_PSK
#define ESP_WIFI_SCAN_AUTH_MODE_THRESHOLD WIFI_AUTH_WPA2_PSK
#elif CONFIG_ESP_WIFI_AUTH_WPA_WPA2_PSK
#define ESP_WIFI_SCAN_AUTH_MODE_THRESHOLD WIFI_AUTH_WPA_WPA2_PSK
#elif CONFIG_ESP_WIFI_AUTH_WPA3_PSK
#define ESP_WIFI_SCAN_AUTH_MODE_THRESHOLD WIFI_AUTH_WPA3_PSK
#elif CONFIG_ESP_WIFI_AUTH_WPA2_WPA3_PSK
#define ESP_WIFI_SCAN_AUTH_MODE_THRESHOLD WIFI_AUTH_WPA2_WPA3_PSK
#elif CONFIG_ESP_WIFI_AUTH_WAPI_PSK
#define ESP_WIFI_SCAN_AUTH_MODE_THRESHOLD WIFI_AUTH_WAPI_PSK
#endif
/* FreeRTOS event group to signal when we are connected*/
static EventGroupHandle_t s_wifi_event_group;
/* The event group allows multiple bits for each event, but we only care about two events:
* - we are connected to the AP with an IP
* - we failed to connect after the maximum amount of retries */
#define WIFI_CONNECTED_BIT BIT0
#define WIFI_FAIL_BIT BIT1
static int s_retry_num = 0;
#define TAG "ESP_Dimmer"
#define CID_ESP 0x0A8B
#define ESP_BLE_MESH_VND_MODEL_ID_SERVER 0x0001
#define ESP_BLE_MESH_VND_MODEL_OP_SEND ESP_BLE_MESH_MODEL_OP_3(0X06, CID_ESP)
#define ESP_BLE_MESH_VND_MODEL_OP_STATUS ESP_BLE_MESH_MODEL_OP_3(0x07, CID_ESP)
extern struct _led_state led_state[3];
static uint8_t dev_uuid[16] = { 0xdd, 0xdd };
esp_mqtt_client_handle_t client_test;
static esp_ble_mesh_cfg_srv_t config_server = {
.relay = ESP_BLE_MESH_RELAY_ENABLED,
.beacon = ESP_BLE_MESH_BEACON_ENABLED,
#if defined(CONFIG_BLE_MESH_FRIEND)
.friend_state = ESP_BLE_MESH_FRIEND_ENABLED,
#else
.friend_state = ESP_BLE_MESH_FRIEND_NOT_SUPPORTED,
#endif
#if defined(CONFIG_BLE_MESH_GATT_PROXY_SERVER)
.gatt_proxy = ESP_BLE_MESH_GATT_PROXY_ENABLED,
#else
.gatt_proxy = ESP_BLE_MESH_GATT_PROXY_NOT_SUPPORTED,
#endif
.default_ttl = 7,
/* 3 transmissions with 20ms interval */
.net_transmit = ESP_BLE_MESH_TRANSMIT(2, 20),
.relay_retransmit = ESP_BLE_MESH_TRANSMIT(2, 20),
ESP_BLE_MESH_MODEL_PUB_DEFINE(vendor_pub, 8, ROLE_NODE); //The publication buffer size must be big enough to fit the longest message to be published.
static esp_ble_mesh_model_op_t vnd_op[] = {
ESP_BLE_MESH_MODEL_OP(ESP_BLE_MESH_VND_MODEL_OP_SEND, 1),
ESP_BLE_MESH_MODEL_OP(ESP_BLE_MESH_VND_MODEL_OP_STATUS, 1),
ESP_BLE_MESH_MODEL_OP_END,
static esp_ble_mesh_model_t vnd_models[] = {
ESP_BLE_MESH_VENDOR_MODEL(CID_ESP, ESP_BLE_MESH_VND_MODEL_ID_SERVER, //vndop à traiter
vnd_op, &vendor_pub, NULL),
//Allocating memory for publishing messages.
ESP_BLE_MESH_MODEL_PUB_DEFINE(onoff_pub_0, 2 + 3, ROLE_NODE);
static esp_ble_mesh_gen_onoff_srv_t onoff_server_0 = {
.rsp_ctrl.get_auto_rsp = ESP_BLE_MESH_SERVER_AUTO_RSP,
.rsp_ctrl.set_auto_rsp = ESP_BLE_MESH_SERVER_AUTO_RSP,
ESP_BLE_MESH_MODEL_PUB_DEFINE(onoff_pub_1, 2 + 3, ROLE_NODE);
static esp_ble_mesh_gen_onoff_srv_t onoff_server_1 = {
.rsp_ctrl.get_auto_rsp = ESP_BLE_MESH_SERVER_RSP_BY_APP,
.rsp_ctrl.set_auto_rsp = ESP_BLE_MESH_SERVER_RSP_BY_APP,
ESP_BLE_MESH_MODEL_PUB_DEFINE(onoff_pub_2, 2 + 3, ROLE_NODE);
static esp_ble_mesh_gen_onoff_srv_t onoff_server_2 = {
static esp_ble_mesh_model_t root_models[] = {
ESP_BLE_MESH_MODEL_CFG_SRV(&config_server),
ESP_BLE_MESH_MODEL_GEN_ONOFF_SRV(&onoff_pub_0, &onoff_server_0),
static esp_ble_mesh_model_t extend_model_0[] = {
ESP_BLE_MESH_MODEL_GEN_ONOFF_SRV(&onoff_pub_1, &onoff_server_1),
static esp_ble_mesh_model_t extend_model_1[] = {
ESP_BLE_MESH_MODEL_GEN_ONOFF_SRV(&onoff_pub_2, &onoff_server_2),
static esp_ble_mesh_elem_t elements[] = {
ESP_BLE_MESH_ELEMENT(0, root_models, ESP_BLE_MESH_MODEL_NONE),
ESP_BLE_MESH_ELEMENT(0, extend_model_0, vnd_models),
ESP_BLE_MESH_ELEMENT(0, extend_model_1, ESP_BLE_MESH_MODEL_NONE),
static esp_ble_mesh_comp_t composition = {
.cid = CID_ESP,
.elements = elements,
.element_count = ARRAY_SIZE(elements),
/* Disable OOB security for SILabs Android app */
static esp_ble_mesh_prov_t provision = {
.uuid = dev_uuid,
#if 0
.output_size = 4,
.output_actions = ESP_BLE_MESH_DISPLAY_NUMBER,
.input_actions = ESP_BLE_MESH_PUSH,
.input_size = 4,
#else
.output_size = 0,
.output_actions = 0,
#endif
static void prov_complete(uint16_t net_idx, uint16_t addr, uint8_t net_key[16], uint8_t flags, uint32_t iv_index)
ESP_LOGI(TAG, "net_idx: 0x%04x, addr: 0x%04x", net_idx, addr);
ESP_LOGI(TAG, "flags: 0x%02x, iv_index: 0x%08" PRIx32, flags, iv_index);
ESP_LOGI(TAG, "net_key/ %02X%02X%02X%02X-%02X%02X-%02X%02X-%02X%02X-%02X%02X%02X%02X%02X%02X",
net_key[0], net_key[1], net_key[2], net_key[3],net_key[4], net_key[5], net_key[6], net_key[7],
net_key[8], net_key[9], net_key[10], net_key[11],net_key[12], net_key[13], net_key[14], net_key[15]);
board_led_operation(LED_B, LED_OFF);
ESP_LOGW(TAG, "LEDs_OFF provisioning completed");
static void example_change_led_state(esp_ble_mesh_model_t *model,
esp_ble_mesh_msg_ctx_t *ctx, uint8_t onoff)
uint16_t primary_addr = esp_ble_mesh_get_primary_element_address();
uint8_t elem_count = esp_ble_mesh_get_element_count();
struct _led_state *led = NULL;
uint8_t i;
if (ESP_BLE_MESH_ADDR_IS_UNICAST(ctx->recv_dst)) {
for (i = 0; i < elem_count; i++) {
if (ctx->recv_dst == (primary_addr + i)) {
led = &led_state[i];
board_led_operation(led->pin, onoff);
} else if (ESP_BLE_MESH_ADDR_IS_GROUP(ctx->recv_dst)) {
if (esp_ble_mesh_is_model_subscribed_to_group(model, ctx->recv_dst)) {
led = &led_state[model->element->element_addr - primary_addr];
} else if (ctx->recv_dst == 0xFFFF) {
static void example_handle_gen_onoff_msg(esp_ble_mesh_model_t *model,
esp_ble_mesh_server_recv_gen_onoff_set_t *set)
esp_ble_mesh_gen_onoff_srv_t *srv = model->user_data;
switch (ctx->recv_op) {
case ESP_BLE_MESH_MODEL_OP_GEN_ONOFF_GET:
ESP_LOGI(TAG, "srv->state.onoff %d", srv->state.onoff);
uint8_t actual_state;
if (srv->state.onoff == 1) {
actual_state = 0x01;
ESP_LOGI(TAG, "status %d", actual_state);
esp_ble_mesh_server_model_send_msg(model, ctx,
ESP_BLE_MESH_MODEL_OP_GEN_ONOFF_STATUS, 0x0001, &actual_state);
ESP_LOGI(TAG, "Status send to src");
actual_state = 0x00;
esp_ble_mesh_model_publish(model, ESP_BLE_MESH_MODEL_OP_GEN_ONOFF_STATUS,
0x0001, &actual_state, ROLE_NODE);
ESP_LOGI(TAG, "Status published (as it was a GET)");
ESP_LOGI(TAG, "sizeof(srv->state.onoff) %d", sizeof(srv->state.onoff));
case ESP_BLE_MESH_MODEL_OP_GEN_ONOFF_SET:
case ESP_BLE_MESH_MODEL_OP_GEN_ONOFF_SET_UNACK:
if (set->op_en == false) {
srv->state.onoff = set->onoff;
/* TODO: Delay and state transition */
if (ctx->recv_op == ESP_BLE_MESH_MODEL_OP_GEN_ONOFF_SET) {
ESP_LOGI(TAG, "It is an Ack Set Message****");
ESP_BLE_MESH_MODEL_OP_GEN_ONOFF_STATUS, sizeof(srv->state.onoff), &srv->state.onoff);
ESP_LOGI(TAG, "Status msg sent Back to src as SET is ACK");
ESP_LOGI(TAG, "ONOFF status published (to suscribers)");
sizeof(srv->state.onoff), &srv->state.onoff, ROLE_NODE);
ESP_LOGI(TAG, "role node {0-1-2} %d", ROLE_NODE);
example_change_led_state(model, ctx, srv->state.onoff);
default:
void send_to_dimmer(uint8_t payload)
printf("payload received by send_to_dimmer() 0x%02x", payload);
esp_ble_mesh_msg_ctx_t ctx = {0};
esp_err_t err = ESP_OK;
ctx.net_idx = 0x0000;
ctx.app_idx = 0x0000;
ctx.addr = 0x3401; /* dimmer */
ctx.send_ttl = ESP_BLE_MESH_TTL_DEFAULT;
ctx.send_rel = false;
err = esp_ble_mesh_server_model_send_msg(&vnd_models[0],&ctx,
ESP_BLE_MESH_VND_MODEL_OP_SEND, sizeof(payload), &payload);
if (err) {
ESP_LOGI(TAG, "Send message to dimmer failed KO");
return;
else {ESP_LOGI(TAG, "Message sent to dimmer OK");}
static void example_ble_mesh_provisioning_cb(esp_ble_mesh_prov_cb_event_t event,
esp_ble_mesh_prov_cb_param_t *param)
switch (event) {
case ESP_BLE_MESH_PROV_REGISTER_COMP_EVT:
ESP_LOGI(TAG, "Initialize BLE Mesh provisioning capabilities and internal data information completion event (esp_ble_mesh_init)");
ESP_LOGI(TAG, "ESP_BLE_MESH_PROV_REGISTER_COMP_EVT, err_code %d", param->prov_register_comp.err_code);
case ESP_BLE_MESH_NODE_PROV_ENABLE_COMP_EVT:
ESP_LOGI(TAG, "Enable node provisioning functionality completion event");
ESP_LOGI(TAG, "ESP_BLE_MESH_NODE_PROV_ENABLE_COMP_EVT, err_code %d", param->node_prov_enable_comp.err_code);
case ESP_BLE_MESH_NODE_PROV_LINK_OPEN_EVT:
ESP_LOGI(TAG, "Establish a BLE Mesh link event");
ESP_LOGI(TAG, "ESP_BLE_MESH_NODE_PROV_LINK_OPEN_EVT, bearer %s",
param->node_prov_link_open.bearer == ESP_BLE_MESH_PROV_ADV ? "PB-ADV" : "PB-GATT");
case ESP_BLE_MESH_NODE_PROV_LINK_CLOSE_EVT:
ESP_LOGI(TAG, "Close a BLE Mesh link event");
ESP_LOGI(TAG, "ESP_BLE_MESH_NODE_PROV_LINK_CLOSE_EVT, bearer %s",
param->node_prov_link_close.bearer == ESP_BLE_MESH_PROV_ADV ? "PB-ADV" : "PB-GATT");
case ESP_BLE_MESH_NODE_PROV_COMPLETE_EVT:
ESP_LOGI(TAG, "Provisioning done event");
ESP_LOGI(TAG, "ESP_BLE_MESH_NODE_PROV_COMPLETE_EVT");
prov_complete(param->node_prov_complete.net_idx, param->node_prov_complete.addr, param->node_prov_complete.net_key,
param->node_prov_complete.flags, param->node_prov_complete.iv_index);
case ESP_BLE_MESH_NODE_PROV_RESET_EVT:
ESP_LOGI(TAG, "Provisioning reset event");
ESP_LOGI(TAG, "ESP_BLE_MESH_NODE_PROV_RESET_EVT");
case ESP_BLE_MESH_NODE_SET_UNPROV_DEV_NAME_COMP_EVT:
ESP_LOGI(TAG, "Set the unprovisioned device name completion event");
ESP_LOGI(TAG, "ESP_BLE_MESH_NODE_SET_UNPROV_DEV_NAME_COMP_EVT, err_code %d", param->node_set_unprov_dev_name_comp.err_code);
default:
static void example_ble_mesh_generic_server_cb(esp_ble_mesh_generic_server_cb_event_t event,
esp_ble_mesh_generic_server_cb_param_t *param)
ESP_LOGI(TAG, "\n\n****CallBack Gen OnOff Server****");
esp_ble_mesh_gen_onoff_srv_t *srv;
ESP_LOGI(TAG, "\nInfos param->model");
ESP_LOGI(TAG, "model_id 0x%04x", param->model->model_id);
ESP_LOGI(TAG, "opcode 0x%04" PRIx32, param->model->op->opcode);
ESP_LOGI(TAG, "op min length %d", param->model->op->min_len);
ESP_LOGI(TAG, "publish_addr 0x%04x", param->model->pub->publish_addr);
ESP_LOGI(TAG, "dev_role %d", param->model->pub->dev_role);
ESP_LOGI(TAG, "\nInfos param->ctx");
ESP_LOGI(TAG, "event 0x%02x, opcode 0x%04" PRIx32 ", src 0x%04x, dst 0x%04x, ttl value 0x%02x",
event, param->ctx.recv_op, param->ctx.addr, param->ctx.recv_dst, param->ctx.recv_ttl);
switch (event) {
case ESP_BLE_MESH_GENERIC_SERVER_STATE_CHANGE_EVT: //set_auto_rsp is set to ESP_BLE_MESH_SERVER_AUTO_RSP
ESP_LOGI(TAG, "ESP_BLE_MESH_GENERIC_SERVER_STATE_CHANGE_EVT");
if (param->ctx.recv_op == ESP_BLE_MESH_MODEL_OP_GEN_ONOFF_SET ||
param->ctx.recv_op == ESP_BLE_MESH_MODEL_OP_GEN_ONOFF_SET_UNACK) {
ESP_LOGI(TAG, "onoff 0x%02x", param->value.state_change.onoff_set.onoff);
example_change_led_state(param->model, ¶m->ctx, param->value.state_change.onoff_set.onoff);
case ESP_BLE_MESH_GENERIC_SERVER_RECV_GET_MSG_EVT: //get_auto_rsp is set to ESP_BLE_MESH_SERVER_RSP_BY_APP
ESP_LOGI(TAG, "\n\nGET Message received****");
ESP_LOGI(TAG, "ESP_BLE_MESH_GENERIC_SERVER_RECV_GET_MSG_EVT");
if (param->ctx.recv_op == ESP_BLE_MESH_MODEL_OP_GEN_ONOFF_GET) {
srv = param->model->user_data; // srv = état du server
ESP_LOGI(TAG, "Server State onoff 0x%02x", srv->state.onoff);
example_handle_gen_onoff_msg(param->model, ¶m->ctx, NULL);
case ESP_BLE_MESH_GENERIC_SERVER_RECV_SET_MSG_EVT: //set_auto_rsp is set to ESP_BLE_MESH_SERVER_RSP_BY_APP
ESP_LOGI(TAG, "SET Message received****");
ESP_LOGI(TAG, "ESP_BLE_MESH_GENERIC_SERVER_RECV_SET_MSG_EVT");
ESP_LOGI(TAG, "SET Message content****");
ESP_LOGI(TAG, "onoff 0x%02x, tid 0x%02x, optional_param %d", param->value.set.onoff.onoff, param->value.set.onoff.tid, param->value.set.onoff.op_en);
if (param->value.set.onoff.op_en) {
ESP_LOGI(TAG, "trans_time 0x%02x, delay 0x%02x",
param->value.set.onoff.trans_time, param->value.set.onoff.delay);
example_handle_gen_onoff_msg(param->model, ¶m->ctx, ¶m->value.set.onoff);
default:
ESP_LOGE(TAG, "Unknown Generic Server event 0x%02x", event);
static void example_ble_mesh_config_server_cb(esp_ble_mesh_cfg_server_cb_event_t event,
esp_ble_mesh_cfg_server_cb_param_t *param)
if (event == ESP_BLE_MESH_CFG_SERVER_STATE_CHANGE_EVT) {
ESP_LOGI(TAG, "****CallBack Config Server****");
ESP_LOGI(TAG, "Params de l'event");
ESP_LOGI(TAG, "source 0x%04x", param->ctx.addr);
ESP_LOGI(TAG, "destination 0x%04x", param->ctx.recv_dst);
ESP_LOGI(TAG, "ttl value 0x%02x", param->ctx.recv_ttl);
ESP_LOGI(TAG, "received op 0x%04" PRIx32, param->ctx.recv_op);
switch (param->ctx.recv_op) { // uint32_t recv_op - Opcode of a received message. Not used for sending message.
case ESP_BLE_MESH_MODEL_OP_APP_KEY_ADD:
ESP_LOGI(TAG, "ESP_BLE_MESH_MODEL_OP_APP_KEY_ADD => Config AppKey Add");
ESP_LOGI(TAG, "net_idx 0x%04x, app_idx 0x%04x, app_key %02X%02X%02X%02X-%02X%02X-%02X%02X-%02X%02X-%02X%02X%02X%02X%02X%02X",
param->value.state_change.appkey_add.net_idx,
param->value.state_change.appkey_add.app_idx,
param->value.state_change.appkey_add.app_key[0],
param->value.state_change.appkey_add.app_key[1],
param->value.state_change.appkey_add.app_key[2],
param->value.state_change.appkey_add.app_key[3],
param->value.state_change.appkey_add.app_key[4],
param->value.state_change.appkey_add.app_key[5],
param->value.state_change.appkey_add.app_key[6],
param->value.state_change.appkey_add.app_key[7],
param->value.state_change.appkey_add.app_key[8],
param->value.state_change.appkey_add.app_key[9],
param->value.state_change.appkey_add.app_key[10],
param->value.state_change.appkey_add.app_key[11],
param->value.state_change.appkey_add.app_key[12],
param->value.state_change.appkey_add.app_key[13],
param->value.state_change.appkey_add.app_key[14],
param->value.state_change.appkey_add.app_key[15]
ESP_LOG_BUFFER_HEX("AppKey", param->value.state_change.appkey_add.app_key, 16);
case ESP_BLE_MESH_MODEL_OP_MODEL_APP_BIND:
ESP_LOGI(TAG, "ESP_BLE_MESH_MODEL_OP_MODEL_APP_BIND => Config Model App Bind");
ESP_LOGI(TAG, "elem_addr 0x%04x, app_idx 0x%04x, cid 0x%04x, mod_id 0x%04x",
param->value.state_change.mod_app_bind.element_addr,
param->value.state_change.mod_app_bind.app_idx,
param->value.state_change.mod_app_bind.company_id,
param->value.state_change.mod_app_bind.model_id);
case ESP_BLE_MESH_MODEL_OP_MODEL_SUB_ADD:
ESP_LOGI(TAG, "ESP_BLE_MESH_MODEL_OP_MODEL_SUB_ADD => Config Model Subscription Add");
ESP_LOGI(TAG, "elem_addr 0x%04x, sub_addr 0x%04x, cid 0x%04x, mod_id 0x%04x",
param->value.state_change.mod_sub_add.element_addr,
param->value.state_change.mod_sub_add.sub_addr,
param->value.state_change.mod_sub_add.company_id,
param->value.state_change.mod_sub_add.model_id);
default:
static void example_ble_mesh_custom_model_cb(esp_ble_mesh_model_cb_event_t event,
esp_ble_mesh_model_cb_param_t *param)
ESP_LOGI(TAG, "\n\n****CallBack Vendor Server****");
switch (event) {
case ESP_BLE_MESH_MODEL_OPERATION_EVT:
ESP_LOGI(TAG, "\n\nESP_BLE_MESH_MODEL_OPERATION_EVT = msg received");
ESP_LOGI(TAG, "\nInfos param->model_operation");
ESP_LOGI(TAG, "Length of the received message 0x%04x", param->model_operation.length);
ESP_LOGI(TAG, "Value of the received message %d", *param->model_operation.msg);
ESP_LOGI(TAG, "model_id 0x%04x", param->model_operation.model->model_id);
ESP_LOGI(TAG, "Opcode of the received message 0x%04" PRIx32, param->model_operation.opcode);
ESP_LOGI(TAG, "op min length %d", param->model_operation.model->op->min_len);
ESP_LOGI(TAG, "publish_addr 0x%04x", param->model_operation.model->pub->publish_addr);
ESP_LOGI(TAG, "dev_role %d", param->model_operation.model->pub->dev_role);
ESP_LOGI(TAG, "event 0x%02x, Opcode of a received message 0x%04" PRIx32 ", src 0x%04x, dst 0x%04x, ttl value 0x%02x",
event, param->model_operation.ctx->recv_op, param->model_operation.ctx->addr, param->model_operation.ctx->recv_dst, param->model_operation.ctx->recv_ttl);
if (param->model_operation.opcode == ESP_BLE_MESH_VND_MODEL_OP_SEND) {
// uint16_t tid = *(uint16_t *)param->model_operation.msg;
ESP_LOGI(TAG, "Recv 0x%06" PRIx32 ", payload 0x%d", param->model_operation.opcode, *param->model_operation.msg);
esp_err_t err = esp_ble_mesh_server_model_send_msg(&vnd_models[0],
param->model_operation.ctx, ESP_BLE_MESH_VND_MODEL_OP_STATUS,
sizeof(*param->model_operation.msg), param->model_operation.msg);
if (err) {
ESP_LOGE(TAG, "Failed to send message 0x%06x", ESP_BLE_MESH_VND_MODEL_OP_STATUS);
} else {ESP_LOGI(TAG, "Status Message sent back to src");}
esp_err_t err2 = esp_ble_mesh_model_publish(&vnd_models[0],
sizeof(*param->model_operation.msg), param->model_operation.msg, ROLE_NODE);
if (err2) {
ESP_LOGE(TAG, "Failed to publish message 0x%06x", ESP_BLE_MESH_VND_MODEL_OP_STATUS);
} else {ESP_LOGI(TAG, "Status Message published");}
send_to_dimmer(*param->model_operation.msg); // forward received message to dimmer
if (param->model_operation.opcode == ESP_BLE_MESH_VND_MODEL_OP_STATUS) {
ESP_LOGI(TAG, "Status Message received");
ESP_LOGI(TAG, "Recv 0x%06" PRIx32, param->model_operation.opcode);
ESP_LOG_BUFFER_HEX("status msg", param->model_operation.msg, 6);
char str[12]; char str2[12];
sprintf(str, "%d", (int) param->model_operation.msg[4]);
sprintf(str2, "%d", (int) param->model_operation.msg[5]);
strcat(str,"-"); strcat(str,str2);
esp_mqtt_client_publish(client_test, "Dimmer_status", str, 0, 0, 0);
//** envoyer par MQTT le buffer reçu / enfin les 4 derniers chiffres
case ESP_BLE_MESH_MODEL_PUBLISH_COMP_EVT:
if (param->model_publish_comp.err_code) {
ESP_LOGE(TAG, "Failed to send message %d", param->model_publish_comp.err_code);
ESP_LOGI(TAG, "\n\nESP_BLE_MESH_MODEL_PUBLISH_COMP_EVT = msg published");
ESP_LOGI(TAG, "\nInfos param->model_publish_comp");
ESP_LOGI(TAG, "model_id 0x%04x", param->model_publish_comp.model->model_id);
ESP_LOGI(TAG, "op min length %d", param->model_publish_comp.model->op->min_len);
ESP_LOGI(TAG, "publish_addr 0x%04x", param->model_publish_comp.model->pub->publish_addr);
ESP_LOGI(TAG, "dev_role %d", param->model_publish_comp.model->pub->dev_role);
case ESP_BLE_MESH_CLIENT_MODEL_RECV_PUBLISH_MSG_EVT:
ESP_LOGI(TAG, "\n\ESP_BLE_MESH_CLIENT_MODEL_RECV_PUBLISH_MSG_EVT = receive publish messages event");
ESP_LOGI(TAG, "\nInfos param->client_recv_publish_msg");
ESP_LOGI(TAG, "Length of the received message 0x%04x", param->client_recv_publish_msg.length);
ESP_LOGI(TAG, "Value of the received message %d", *param->client_recv_publish_msg.msg);
ESP_LOGI(TAG, "model_id 0x%04x", param->client_recv_publish_msg.model->model_id);
ESP_LOGI(TAG, "opcode 0x%04" PRIx32, param->client_recv_publish_msg.opcode);
ESP_LOGI(TAG, "op min length %d", param->client_recv_publish_msg.model->op->min_len);
ESP_LOGI(TAG, "publish_addr 0x%04x", param->client_recv_publish_msg.model->pub->publish_addr);
ESP_LOGI(TAG, "dev_role %d", param->client_recv_publish_msg.model->pub->dev_role);
event, param->client_recv_publish_msg.ctx->recv_op, param->client_recv_publish_msg.ctx->addr, param->client_recv_publish_msg.ctx->recv_dst, param->client_recv_publish_msg.ctx->recv_ttl);
case ESP_BLE_MESH_MODEL_SEND_COMP_EVT:
if (param->model_send_comp.err_code) {
ESP_LOGE(TAG, "Failed to send message 0x%06" PRIx32, param->model_send_comp.opcode);
ESP_LOGI(TAG, "\n\ESP_BLE_MESH_MODEL_SEND_COMP_EVT = send messages completion event");
ESP_LOGI(TAG, "\nInfos param->model_send_comp");
ESP_LOGI(TAG, "model_id 0x%04x", param->model_send_comp.model->model_id);
ESP_LOGI(TAG, "Opcode of the message 0x%04" PRIx32, param->model_send_comp.opcode);
ESP_LOGI(TAG, "op min length %d", param->model_send_comp.model->op->min_len);
ESP_LOGI(TAG, "publish_addr 0x%04x", param->model_send_comp.model->pub->publish_addr);
ESP_LOGI(TAG, "dev_role %d", param->model_send_comp.model->pub->dev_role);
event, param->model_send_comp.ctx->recv_op, param->model_send_comp.ctx->addr, param->model_send_comp.ctx->recv_dst, param->model_send_comp.ctx->recv_ttl);
default:
int str2int(const char* str, int len)
int i;
int ret = 0;
for(i = 0; i < len; ++i)
ret = ret * 10 + (str[i] - '0');
return ret;
static void mqtt_event_handler(void *handler_args, esp_event_base_t base, int32_t event_id, void *event_data)
ESP_LOGD(TAG, "Event dispatched from event loop base=%s, event_id=%d", base, event_id);
esp_mqtt_event_handle_t event = event_data;
esp_mqtt_client_handle_t client = event->client;
client_test = event->client;
int msg_id;
switch ((esp_mqtt_event_id_t)event_id) {
case MQTT_EVENT_CONNECTED:
ESP_LOGI(TAG, "MQTT_EVENT_CONNECTED");
msg_id = esp_mqtt_client_subscribe(client, "BTmesh_dimmer", 0);
ESP_LOGI(TAG, "sent subscribe successful, msg_id=%d", msg_id);
msg_id = esp_mqtt_client_subscribe(client, "Dimmer", 0);
case MQTT_EVENT_DISCONNECTED:
ESP_LOGI(TAG, "MQTT_EVENT_DISCONNECTED");
case MQTT_EVENT_SUBSCRIBED:
ESP_LOGI(TAG, "MQTT_EVENT_SUBSCRIBED, msg_id=%d", event->msg_id);
case MQTT_EVENT_UNSUBSCRIBED:
ESP_LOGI(TAG, "MQTT_EVENT_UNSUBSCRIBED, msg_id=%d", event->msg_id);
case MQTT_EVENT_PUBLISHED:
ESP_LOGI(TAG, "MQTT_EVENT_PUBLISHED, msg_id=%d", event->msg_id);
case MQTT_EVENT_DATA:
// ESP_LOGI(TAG, "MQTT_EVENT_DATA");
if (strncmp("BTmesh_dimmer", event->topic, 13) == 0) {
// printf("TOPIC=%.*s\r\n", event->topic_len, event->topic);
printf("DATA=%.*s\r\n", event->data_len, event->data);
ESP_LOGI(TAG, "BTmesh_dimmer OK");
int data_as_int = str2int(event->data, event->data_len);
printf("typecast of data_as_int for send_to_dimmer 0x%02x\n", (uint8_t) data_as_int);
send_to_dimmer((uint8_t) data_as_int);
else if (strncmp("Dimmer", event->topic, 6) == 0) {esp_mqtt_client_publish(client, "Dimmer_back", "ok", 0, 0, 0);}
case MQTT_EVENT_ERROR:
ESP_LOGI(TAG, "MQTT_EVENT_ERROR");
// if (event->error_handle->error_type == MQTT_ERROR_TYPE_TCP_TRANSPORT) {
// log_error_if_nonzero("reported from esp-tls", event->error_handle->esp_tls_last_esp_err);
// log_error_if_nonzero("reported from tls stack", event->error_handle->esp_tls_stack_err);
// log_error_if_nonzero("captured as transport's socket errno", event->error_handle->esp_transport_sock_errno);
// ESP_LOGI(TAG, "Last errno string (%s)", strerror(event->error_handle->esp_transport_sock_errno));
default:
ESP_LOGI(TAG, "Other event id:%d", event->event_id);
static void mqtt_app_start(void)
esp_mqtt_client_config_t mqtt_cfg = {
.broker.address.uri = CONFIG_BROKER_URL,
#if CONFIG_BROKER_URL_FROM_STDIN
char line[128];
if (strcmp(mqtt_cfg.broker.address.uri, "FROM_STDIN") == 0) {
int count = 0;
printf("Please enter url of mqtt broker\n");
while (count < 128) {
int c = fgetc(stdin);
if (c == '\n') {
line[count] = '\0';
} else if (c > 0 && c < 127) {
line[count] = c;
++count;
vTaskDelay(10 / portTICK_PERIOD_MS);
mqtt_cfg.broker.address.uri = line;
printf("Broker url: %s\n", line);
ESP_LOGE(TAG, "Configuration mismatch: wrong broker url");
abort();
#endif /* CONFIG_BROKER_URL_FROM_STDIN */
esp_mqtt_client_handle_t client = esp_mqtt_client_init(&mqtt_cfg);
/* The last argument may be used to pass data to the event handler, in this example mqtt_event_handler */
esp_mqtt_client_register_event(client, ESP_EVENT_ANY_ID, mqtt_event_handler, NULL);
esp_mqtt_client_start(client);
static esp_err_t ble_mesh_init(void)
// => cb with prov_cb_event (ENUMERATOR) et param (union) en fonction des event
esp_ble_mesh_register_prov_callback(example_ble_mesh_provisioning_cb);
//* `esp_ble_mesh_register_prov_callback(esp_ble_mesh_prov_cb)`: registers the provisioning callback function in the BLE Mesh stack.
//* This callback function gets executed during the BLE Mesh network configuration process. It allows the BLE Mesh stack to generate
//* events and notify the application layer about important network configuration processes.
// => cb with serv_cb_event (ESP_BLE_MESH_CFG_SERVER_STATE_CHANGE_EVT), param => model (id, op, user_data), ctx(addr=source, app, net, dst=this), value(state_change)
esp_ble_mesh_register_config_server_callback(example_ble_mesh_config_server_cb);
//* `esp_ble_mesh_register_custom_model_callback(esp_ble_mesh_model_cb)`: registers the model operation callback function.
//* This callback function is used when the target peer operates the model state of the source peer after BLE Mesh has completed network
//* configuration.
esp_ble_mesh_register_generic_server_callback(example_ble_mesh_generic_server_cb); // => cb with generic_server_cb_event (ENUMERATOR) et param (pointer model Serv, ctx of received msg, cb_value of msg) en fonction des event semberait il
esp_ble_mesh_register_custom_model_callback(example_ble_mesh_custom_model_cb);
// Initialize BLE Mesh module. This API initializes provisioning capabilities and composition data information.
err = esp_ble_mesh_init(&provision, &composition);
if (err != ESP_OK) {
ESP_LOGE(TAG, "Failed to initialize mesh stack (err %d)", err);
return err;
ESP_LOGW(TAG, "BLE Mesh stack initialized (prov & comp settings)");
//* enables the Advertising and Scan functions when the BLE Mesh initialization is completed.
//* It makes the devices visible to Provisioners for network provisioning.
err = esp_ble_mesh_node_prov_enable(ESP_BLE_MESH_PROV_ADV | ESP_BLE_MESH_PROV_GATT);
ESP_LOGW(TAG, "BLE Mesh Node initialized: visible to Provisioners");
ESP_LOGE(TAG, "Failed to enable mesh node (err %d)", err);
return err;
ESP_LOGI(TAG, "BLE Mesh Node initialized");
board_led_operation(LED_B, LED_ON);
ESP_LOGW(TAG, "LEDs_ON waiting for provisioning to complete");
return err;
static void event_handler(void* arg, esp_event_base_t event_base,
int32_t event_id, void* event_data)
if (event_base == WIFI_EVENT && event_id == WIFI_EVENT_STA_START) {
esp_wifi_connect();
} else if (event_base == WIFI_EVENT && event_id == WIFI_EVENT_STA_DISCONNECTED) {
if (s_retry_num < EXAMPLE_ESP_MAXIMUM_RETRY) {
esp_wifi_connect();
s_retry_num++;
ESP_LOGI(TAG, "retry to connect to the AP");
xEventGroupSetBits(s_wifi_event_group, WIFI_FAIL_BIT);
ESP_LOGI(TAG,"connect to the AP fail");
} else if (event_base == IP_EVENT && event_id == IP_EVENT_STA_GOT_IP) {
ip_event_got_ip_t* event = (ip_event_got_ip_t*) event_data;
ESP_LOGI(TAG, "got ip:" IPSTR, IP2STR(&event->ip_info.ip));
s_retry_num = 0;
xEventGroupSetBits(s_wifi_event_group, WIFI_CONNECTED_BIT);
void wifi_init_sta(void)
s_wifi_event_group = xEventGroupCreate();
esp_netif_create_default_wifi_sta();
esp_event_handler_instance_t instance_any_id;
esp_event_handler_instance_t instance_got_ip;
ESP_ERROR_CHECK(esp_event_handler_instance_register(WIFI_EVENT,
ESP_EVENT_ANY_ID,
&event_handler,
NULL,
&instance_any_id));
ESP_ERROR_CHECK(esp_event_handler_instance_register(IP_EVENT,
IP_EVENT_STA_GOT_IP,
&event_handler,
NULL,
&instance_got_ip));
wifi_config_t wifi_config = {
.sta = {
.ssid = EXAMPLE_ESP_WIFI_SSID,
.password = EXAMPLE_ESP_WIFI_PASS,
/* Authmode threshold resets to WPA2 as default if password matches WPA2 standards (pasword len => 8).
* If you want to connect the device to deprecated WEP/WPA networks, Please set the threshold value
* to WIFI_AUTH_WEP/WIFI_AUTH_WPA_PSK and set the password with length and format matching to
* WIFI_AUTH_WEP/WIFI_AUTH_WPA_PSK standards.
.threshold.authmode = ESP_WIFI_SCAN_AUTH_MODE_THRESHOLD,
.sae_pwe_h2e = WPA3_SAE_PWE_BOTH,
ESP_ERROR_CHECK(esp_wifi_set_mode(WIFI_MODE_STA) );
ESP_ERROR_CHECK(esp_wifi_set_config(WIFI_IF_STA, &wifi_config) );
ESP_ERROR_CHECK(esp_wifi_start() );
ESP_LOGI(TAG, "wifi_init_sta finished.");
/* Waiting until either the connection is established (WIFI_CONNECTED_BIT) or connection failed for the maximum
* number of re-tries (WIFI_FAIL_BIT). The bits are set by event_handler() (see above) */
EventBits_t bits = xEventGroupWaitBits(s_wifi_event_group,
WIFI_CONNECTED_BIT | WIFI_FAIL_BIT,
pdFALSE,
pdFALSE,
portMAX_DELAY);
/* xEventGroupWaitBits() returns the bits before the call returned, hence we can test which event actually
* happened. */
if (bits & WIFI_CONNECTED_BIT) {
ESP_LOGI(TAG, "connected to ap SSID:%s password:%s",
EXAMPLE_ESP_WIFI_SSID, EXAMPLE_ESP_WIFI_PASS);
} else if (bits & WIFI_FAIL_BIT) {
ESP_LOGI(TAG, "Failed to connect to SSID:%s, password:%s",
ESP_LOGE(TAG, "UNEXPECTED EVENT");
void app_main(void)
esp_err_t err;
ESP_LOGI(TAG, "Initializing...");
board_init();
err = nvs_flash_init();
if (err == ESP_ERR_NVS_NO_FREE_PAGES) {
ESP_ERROR_CHECK(err);
ESP_LOGI(TAG, "ESP_WIFI_MODE_STA");
wifi_init_sta();
err = bluetooth_init();
if (err) {
ESP_LOGE(TAG, "esp32_bluetooth_init failed (err %d)", err);
return;
ESP_LOGI(TAG, "Bluetooth initialised OK\n");
ble_mesh_get_dev_uuid(dev_uuid);
/* Initialize the Bluetooth Mesh Subsystem */
err = ble_mesh_init();
if (err) {
ESP_LOGE(TAG, "Bluetooth mesh init failed (err %d)", err);
ESP_LOGI(TAG, "Mesh initialised OK\n");
mqtt_app_start();
cmake_minimum_required(VERSION 3.16)
set(EXTRA_COMPONENT_DIRS $ENV{IDF_PATH}/examples/bluetooth/esp_ble_mesh/common_components/example_init
$ENV{IDF_PATH}/examples/common_components/protocol_examples_common)
project(ESP32_dimmer)
menu "Example Configuration"
config BROKER_URL
string "Broker URL"
default "mqtt://mqtt.eclipseprojects.io"
help
URL of the broker to connect to
config BROKER_URL_FROM_STDIN
bool
default y if BROKER_URL = "FROM_STDIN"
choice BLE_MESH_EXAMPLE_BOARD
prompt "Board selection for BLE Mesh"
default BLE_MESH_ESP_WROOM_32 if IDF_TARGET_ESP32
default BLE_MESH_ESP32C3_DEV if IDF_TARGET_ESP32C3
default BLE_MESH_ESP32S3_DEV if IDF_TARGET_ESP32S3
help
Select this option to choose the board for BLE Mesh. The default is ESP32-WROOM-32
config BLE_MESH_ESP_WROOM_32
bool "ESP32-WROOM-32"
depends on IDF_TARGET_ESP32
config BLE_MESH_ESP_WROVER
bool "ESP32-WROVER"
config BLE_MESH_ESP32C3_DEV
bool "ESP32C3-DevKitC"
depends on IDF_TARGET_ESP32C3
config BLE_MESH_ESP32S3_DEV
bool "ESP32S3-DevKitC"
depends on IDF_TARGET_ESP32S3
endchoice
config ESP_WIFI_SSID
string "WiFi SSID"
default "myssid"
help
SSID (network name) for the example to connect to.
config ESP_WIFI_PASSWORD
string "WiFi Password"
default "mypassword"
help
WiFi password (WPA or WPA2) for the example to use.
config ESP_MAXIMUM_RETRY
int "Maximum retry"
default 5
help
Set the Maximum retry to avoid station reconnecting to the AP unlimited when the AP is really inexistent.
choice ESP_WIFI_SCAN_AUTH_MODE_THRESHOLD
prompt "WiFi Scan auth mode threshold"
default ESP_WIFI_AUTH_WPA2_PSK
help
The weakest authmode to accept in the scan mode.
This value defaults to ESP_WIFI_AUTH_WPA2_PSK incase password is present and ESP_WIFI_AUTH_OPEN is used.
Please select ESP_WIFI_AUTH_WEP/ESP_WIFI_AUTH_WPA_PSK incase AP is operating in WEP/WPA mode.
config ESP_WIFI_AUTH_OPEN
bool "OPEN"
config ESP_WIFI_AUTH_WEP
bool "WEP"
config ESP_WIFI_AUTH_WPA_PSK
bool "WPA PSK"
config ESP_WIFI_AUTH_WPA2_PSK
bool "WPA2 PSK"
config ESP_WIFI_AUTH_WPA_WPA2_PSK
bool "WPA/WPA2 PSK"
config ESP_WIFI_AUTH_WPA3_PSK
bool "WPA3 PSK"
config ESP_WIFI_AUTH_WPA2_WPA3_PSK
bool "WPA2/WPA3 PSK"
config ESP_WIFI_AUTH_WAPI_PSK
bool "WAPI PSK"
endchoice
endmenu
esp32besbar
my sdk config (only important topics here)
# Partition Table (very important)
# CONFIG_PARTITION_TABLE_SINGLE_APP is not set
# CONFIG_PARTITION_TABLE_SINGLE_APP_LARGE is not set
# CONFIG_PARTITION_TABLE_TWO_OTA is not set
CONFIG_PARTITION_TABLE_CUSTOM=y
CONFIG_PARTITION_TABLE_CUSTOM_FILENAME="partitions.csv"
CONFIG_PARTITION_TABLE_FILENAME="partitions.csv"
CONFIG_PARTITION_TABLE_OFFSET=0x8000
CONFIG_PARTITION_TABLE_MD5=y
# end of Partition Table
# Example Configuration
CONFIG_BROKER_URL="XXXXX" <= your setup
CONFIG_BLE_MESH_ESP_WROOM_32=y
# CONFIG_BLE_MESH_ESP_WROVER is not set
CONFIG_ESP_WIFI_SSID="XXXXX"<= your setup
CONFIG_ESP_WIFI_PASSWORD="XXXXX"<= your setup
CONFIG_ESP_MAXIMUM_RETRY=5
# CONFIG_ESP_WIFI_AUTH_OPEN is not set
# CONFIG_ESP_WIFI_AUTH_WEP is not set
# CONFIG_ESP_WIFI_AUTH_WPA_PSK is not set
CONFIG_ESP_WIFI_AUTH_WPA2_PSK=y
# CONFIG_ESP_WIFI_AUTH_WPA_WPA2_PSK is not set
# CONFIG_ESP_WIFI_AUTH_WPA3_PSK is not set
# CONFIG_ESP_WIFI_AUTH_WPA2_WPA3_PSK is not set
# CONFIG_ESP_WIFI_AUTH_WAPI_PSK is not set
# end of Example Configuration
# Example Connection Configuration
CONFIG_ENV_GPIO_RANGE_MIN=0
CONFIG_ENV_GPIO_RANGE_MAX=39
CONFIG_ENV_GPIO_IN_RANGE_MAX=39
CONFIG_ENV_GPIO_OUT_RANGE_MAX=33
CONFIG_EXAMPLE_CONNECT_WIFI=y
# CONFIG_EXAMPLE_WIFI_SSID_PWD_FROM_STDIN is not set
CONFIG_EXAMPLE_PROVIDE_WIFI_CONSOLE_CMD=y
CONFIG_EXAMPLE_WIFI_SSID="XXXXXX"
CONFIG_EXAMPLE_WIFI_PASSWORD="XXXXXX"
CONFIG_EXAMPLE_WIFI_CONN_MAX_RETRY=6
# CONFIG_EXAMPLE_WIFI_SCAN_METHOD_FAST is not set
CONFIG_EXAMPLE_WIFI_SCAN_METHOD_ALL_CHANNEL=y
# WiFi Scan threshold
CONFIG_EXAMPLE_WIFI_SCAN_RSSI_THRESHOLD=-127
CONFIG_EXAMPLE_WIFI_AUTH_OPEN=y
# CONFIG_EXAMPLE_WIFI_AUTH_WEP is not set
# CONFIG_EXAMPLE_WIFI_AUTH_WPA_PSK is not set
# CONFIG_EXAMPLE_WIFI_AUTH_WPA2_PSK is not set
# CONFIG_EXAMPLE_WIFI_AUTH_WPA_WPA2_PSK is not set
# CONFIG_EXAMPLE_WIFI_AUTH_WPA2_ENTERPRISE is not set
# CONFIG_EXAMPLE_WIFI_AUTH_WPA3_PSK is not set
# CONFIG_EXAMPLE_WIFI_AUTH_WPA2_WPA3_PSK is not set
# CONFIG_EXAMPLE_WIFI_AUTH_WAPI_PSK is not set
# end of WiFi Scan threshold
CONFIG_EXAMPLE_WIFI_CONNECT_AP_BY_SIGNAL=y
# CONFIG_EXAMPLE_WIFI_CONNECT_AP_BY_SECURITY is not set
# CONFIG_EXAMPLE_CONNECT_ETHERNET is not set
CONFIG_EXAMPLE_CONNECT_IPV6=y
CONFIG_EXAMPLE_CONNECT_IPV6_PREF_LOCAL_LINK=y
# CONFIG_EXAMPLE_CONNECT_IPV6_PREF_GLOBAL is not set
# CONFIG_EXAMPLE_CONNECT_IPV6_PREF_SITE_LOCAL is not set
# CONFIG_EXAMPLE_CONNECT_IPV6_PREF_UNIQUE_LOCAL is not set
# end of Example Connection Configuration
CONFIG_BLE_MESH=y
CONFIG_BLE_MESH_HCI_5_0=y
CONFIG_BLE_MESH_USE_DUPLICATE_SCAN=y
CONFIG_BLE_MESH_MEM_ALLOC_MODE_INTERNAL=y
# CONFIG_BLE_MESH_MEM_ALLOC_MODE_DEFAULT is not set
CONFIG_BLE_MESH_DEINIT=y
# BLE Mesh and BLE coexistence support
# CONFIG_BLE_MESH_SUPPORT_BLE_ADV is not set
# CONFIG_BLE_MESH_SUPPORT_BLE_SCAN is not set
# end of BLE Mesh and BLE coexistence support
# CONFIG_BLE_MESH_FAST_PROV is not set
CONFIG_BLE_MESH_NODE=y
# CONFIG_BLE_MESH_PROVISIONER is not set
CONFIG_BLE_MESH_PROV=y
CONFIG_BLE_MESH_PB_ADV=y
CONFIG_BLE_MESH_UNPROVISIONED_BEACON_INTERVAL=5
CONFIG_BLE_MESH_PB_GATT=y
CONFIG_BLE_MESH_PROXY=y
CONFIG_BLE_MESH_GATT_PROXY_SERVER=y
CONFIG_BLE_MESH_NODE_ID_TIMEOUT=60
CONFIG_BLE_MESH_PROXY_FILTER_SIZE=4
# CONFIG_BLE_MESH_GATT_PROXY_CLIENT is not set
CONFIG_BLE_MESH_NET_BUF_POOL_USAGE=y
CONFIG_BLE_MESH_SETTINGS=y
CONFIG_BLE_MESH_STORE_TIMEOUT=0
CONFIG_BLE_MESH_SEQ_STORE_RATE=0
CONFIG_BLE_MESH_RPL_STORE_TIMEOUT=0
# CONFIG_BLE_MESH_SETTINGS_BACKWARD_COMPATIBILITY is not set
# CONFIG_BLE_MESH_SPECIFIC_PARTITION is not set
CONFIG_BLE_MESH_SUBNET_COUNT=3
CONFIG_BLE_MESH_APP_KEY_COUNT=3
CONFIG_BLE_MESH_MODEL_KEY_COUNT=3
CONFIG_BLE_MESH_MODEL_GROUP_COUNT=3
CONFIG_BLE_MESH_LABEL_COUNT=3
CONFIG_BLE_MESH_CRPL=40
CONFIG_BLE_MESH_MSG_CACHE_SIZE=10
CONFIG_BLE_MESH_ADV_BUF_COUNT=60
CONFIG_BLE_MESH_IVU_DIVIDER=4
# CONFIG_BLE_MESH_IVU_RECOVERY_IVI is not set
CONFIG_BLE_MESH_TX_SEG_MSG_COUNT=10
CONFIG_BLE_MESH_RX_SEG_MSG_COUNT=10
CONFIG_BLE_MESH_RX_SDU_MAX=384
CONFIG_BLE_MESH_TX_SEG_MAX=32
CONFIG_BLE_MESH_RELAY=y
# CONFIG_BLE_MESH_RELAY_ADV_BUF is not set
# CONFIG_BLE_MESH_LOW_POWER is not set
# CONFIG_BLE_MESH_FRIEND is not set
# CONFIG_BLE_MESH_NO_LOG is not set
# BLE Mesh STACK DEBUG LOG LEVEL
# CONFIG_BLE_MESH_TRACE_LEVEL_NONE is not set
# CONFIG_BLE_MESH_TRACE_LEVEL_ERROR is not set
CONFIG_BLE_MESH_TRACE_LEVEL_WARNING=y
# CONFIG_BLE_MESH_TRACE_LEVEL_INFO is not set
# CONFIG_BLE_MESH_TRACE_LEVEL_DEBUG is not set
# CONFIG_BLE_MESH_TRACE_LEVEL_VERBOSE is not set
CONFIG_BLE_MESH_STACK_TRACE_LEVEL=2
# end of BLE Mesh STACK DEBUG LOG LEVEL
# BLE Mesh NET BUF DEBUG LOG LEVEL
# CONFIG_BLE_MESH_NET_BUF_TRACE_LEVEL_NONE is not set
# CONFIG_BLE_MESH_NET_BUF_TRACE_LEVEL_ERROR is not set
CONFIG_BLE_MESH_NET_BUF_TRACE_LEVEL_WARNING=y
# CONFIG_BLE_MESH_NET_BUF_TRACE_LEVEL_INFO is not set
# CONFIG_BLE_MESH_NET_BUF_TRACE_LEVEL_DEBUG is not set
# CONFIG_BLE_MESH_NET_BUF_TRACE_LEVEL_VERBOSE is not set
CONFIG_BLE_MESH_NET_BUF_TRACE_LEVEL=2
# end of BLE Mesh NET BUF DEBUG LOG LEVEL
CONFIG_BLE_MESH_CLIENT_MSG_TIMEOUT=4000
# Support for BLE Mesh Foundation models
# CONFIG_BLE_MESH_CFG_CLI is not set
# CONFIG_BLE_MESH_HEALTH_CLI is not set
CONFIG_BLE_MESH_HEALTH_SRV=y
# end of Support for BLE Mesh Foundation models
# Support for BLE Mesh Client/Server models
# CONFIG_BLE_MESH_GENERIC_ONOFF_CLI is not set
# CONFIG_BLE_MESH_GENERIC_LEVEL_CLI is not set
# CONFIG_BLE_MESH_GENERIC_DEF_TRANS_TIME_CLI is not set
# CONFIG_BLE_MESH_GENERIC_POWER_ONOFF_CLI is not set
# CONFIG_BLE_MESH_GENERIC_POWER_LEVEL_CLI is not set
# CONFIG_BLE_MESH_GENERIC_BATTERY_CLI is not set
# CONFIG_BLE_MESH_GENERIC_LOCATION_CLI is not set
# CONFIG_BLE_MESH_GENERIC_PROPERTY_CLI is not set
# CONFIG_BLE_MESH_SENSOR_CLI is not set
# CONFIG_BLE_MESH_TIME_CLI is not set
# CONFIG_BLE_MESH_SCENE_CLI is not set
# CONFIG_BLE_MESH_SCHEDULER_CLI is not set
# CONFIG_BLE_MESH_LIGHT_LIGHTNESS_CLI is not set
# CONFIG_BLE_MESH_LIGHT_CTL_CLI is not set
# CONFIG_BLE_MESH_LIGHT_HSL_CLI is not set
# CONFIG_BLE_MESH_LIGHT_XYL_CLI is not set
# CONFIG_BLE_MESH_LIGHT_LC_CLI is not set
CONFIG_BLE_MESH_GENERIC_SERVER=y
CONFIG_BLE_MESH_SENSOR_SERVER=y
CONFIG_BLE_MESH_TIME_SCENE_SERVER=y
CONFIG_BLE_MESH_LIGHTING_SERVER=y
# end of Support for BLE Mesh Client/Server models
# CONFIG_BLE_MESH_IV_UPDATE_TEST is not set
CONFIG_BLE_MESH_DISCARD_OLD_SEQ_AUTH=y
# BLE Mesh specific test option
# CONFIG_BLE_MESH_SELF_TEST is not set
# CONFIG_BLE_MESH_SHELL is not set
# CONFIG_BLE_MESH_DEBUG is not set
# end of BLE Mesh specific test option
schrodinger_smile
Thank you very, very, very, very much for the code you provided. I have one more question.Do you know which API can get the publishing address of the model?
or maybe I should use that like this: client.model.pub.publish_addr ?
Users browsing this forum: trendictionbot, YisouSpider and 2 guests
