I (277) opi psram: vendor id : 0x0d (AP)
I (277) opi psram: dev id : 0x02 (generation 3)
I (277) opi psram: density : 0x03 (64 Mbit)
I (280) opi psram: good-die : 0x01 (Pass)
I (285) opi psram: Latency : 0x01 (Fixed)
I (290) opi psram: VCC : 0x01 (3V)
I (295) opi psram: SRF : 0x01 (Fast Refresh)
I (300) opi psram: BurstType : 0x01 (Hybrid Wrap)
I (306) opi psram: BurstLen : 0x01 (32 Byte)
I (311) opi psram: Readlatency : 0x02 (10 cycles@Fixed)
I (317) opi psram: DriveStrength: 0x00 (1/1)
W (322) PSRAM: DO NOT USE FOR MASS PRODUCTION! Timing parameters will be updated in future IDF version.
I (332) spiram: Found 64MBit SPI RAM device
I (336) spiram: SPI RAM mode: sram 80m
I (341) spiram: PSRAM initialized, cache is in normal (1-core) mode.
I (348) cpu_start: Pro cpu up.
I (352) cpu_start: Starting app cpu, entry point is 0x40375568
0x40375568: call_start_cpu1 at /home/weilian/esp-idf-v4.4.3_release_path_120mhz/components/esp_system/port/cpu_start.c:148
I (0) cpu_start: App cpu up.
I (367) cpu_start: Pro cpu start user code
I (367) cpu_start: cpu freq: 240000000
I (367) cpu_start: Application information:
I (367) cpu_start: Project name: human_face_detection_web
I (368) cpu_start: App version: v0.9.3-167-g7563e00-dirty
I (368) cpu_start: Compile time: Mar 14 2023 18:43:36
I (368) cpu_start: ELF file SHA256: 91f4aca3aef901b5...
I (368) cpu_start: ESP-IDF: v4.4.3-dirty
I (369) heap_init: Initializing. RAM available for dynamic allocation:
I (369) heap_init: At 3FCA7758 len 00041FB8 (263 KiB): D/IRAM
I (369) heap_init: At 3FCE9710 len 00005724 (21 KiB): STACK/DRAM
I (369) heap_init: At 600FE000 len 00002000 (8 KiB): RTCRAM
I (370) spiram: Adding pool of 8192K of external SPI memory to heap allocator
I (370) spi_flash: detected chip: generic
I (371) spi_flash: flash io: qio
I (375) sleep: Configure to isolate all GPIO pins in sleep state
I (375) sleep: Enable automatic switching of GPIO sleep configuration
I (375) cpu_start: Starting scheduler on PRO CPU.
I (376) spiram: Reserving pool of 32K of internal memory for DMA/internal allocations
I (386) pp: pp rom version: e7ae62f
I (386) net80211: net80211 rom version: e7ae62f
I (396) wifi:wifi driver task: 3fced63c, prio:23, stack:6656, core=0
I (396) system_api: Base MAC address is not set
I (396) system_api: read default base MAC address from EFUSE
I (396) wifi:wifi firmware version: 8cb87ff
I (396) wifi:wifi certification version: v7.0
I (396) wifi:config NVS flash: enabled
I (396) wifi:config nano formating: disabled
I (396) wifi:Init data frame dynamic rx buffer num: 32
I (396) wifi:Init management frame dynamic rx buffer num: 32
I (396) wifi:Init management short buffer num: 32
I (396) wifi:Init static tx buffer num: 16
I (396) wifi:Init tx cache buffer num: 32
I (396) wifi:Init static tx FG buffer num: 2
I (396) wifi:Init static rx buffer size: 1600
I (396) wifi:Init static rx buffer num: 10
I (396) wifi:Init dynamic rx buffer num: 32
I (396) wifi_init: rx ba win: 6
I (396) wifi_init: tcpip mbox: 32
I (396) wifi_init: udp mbox: 6
I (396) wifi_init: tcp mbox: 6
I (396) wifi_init: tcp tx win: 5744
I (396) wifi_init: tcp rx win: 5744
I (396) wifi_init: tcp mss: 1440
I (396) wifi_init: WiFi IRAM OP enabled
I (396) wifi_init: WiFi RX IRAM OP enabled
I (406) camera wifi: wifi_init_softap finished.SSID:Human Face Detection password:
I (406) phy_init: phy_version 503,13653eb,Jun 1 2022,17:47:08
I (436) wifi:mode : softAP (7c:df:a1:e1:a1:b9)
I (436) wifi:Total power save buffer number: 8
I (436) wifi:Init max length of beacon: 752/752
I (436) wifi:Set ps type: 0
I (436) who_camera: Camera module is ESP-S3-EYE
I (436) s3 ll_cam: DMA Channel=4
I (436) cam_hal: cam init ok
I (446) sccb: pin_sda 4 pin_scl 5
I (456) camera: Detected camera at address=0x3c
I (456) camera: Detected OV3660 camera
I (456) camera: Camera PID=0x3660 VER=0x00 MIDL=0x00 MIDH=0x00
I (766) s3 ll_cam: node_size: 3840, nodes_per_line: 1, lines_per_node: 6
I (766) s3 ll_cam: dma_half_buffer_min: 3840, dma_half_buffer: 15360, lines_per_half_buffer: 24, dma_buffer_size: 30720
I (766) cam_hal: buffer_size: 30720, half_buffer_size: 15360, node_buffer_size: 3840, node_cnt: 8, total_cnt: 10
I (766) cam_hal: Allocating 153600 Byte frame buffer in PSRAM
I (766) cam_hal: cam config ok
I (776) ov3660: Calculated VCO: 120000000 Hz, PLLCLK: 60000000 Hz, SYSCLK: 15000000 Hz, PCLK: 7500000 Hz
I (796) camera_httpd: Starting web server on port: '80'
I (796) camera_httpd: Starting stream server on port: '81'
W (5286) cam_hal: Failed to get the frame on time!
ERROR A stack overflow in task who_camera has been detected.
Backtrace: 0x40375e9a:0x3fcd15a0 0x4037de01:0x3fcd15c0 0x4038174e:0x3fcd15e0 0x4037fb1f:0x3fcd1660 0x4037deb8:0x3fcd1680 0x4037deae:0x00000000 |<-CORRUPTED
0x40375e9a: panic_abort at /home/weilian/esp-idf-v4.4.3_release_path_120mhz/components/esp_system/panic.c:402
0x4037de01: esp_system_abort at /home/weilian/esp-idf-v4.4.3_release_path_120mhz/components/esp_system/esp_system.c:128
0x4038174e: vApplicationStackOverflowHook at /home/weilian/esp-idf-v4.4.3_release_path_120mhz/components/freertos/port/xtensa/port.c:394
0x4037fb1f: vTaskSwitchContext at /home/weilian/esp-idf-v4.4.3_release_path_120mhz/components/freertos/tasks.c:3505
0x4037deb8: _frxt_dispatch at /home/weilian/esp-idf-v4.4.3_release_path_120mhz/components/freertos/port/xtensa/portasm.S:436
0x4037deae: _frxt_int_exit at /home/weilian/esp-idf-v4.4.3_release_path_120mhz/components/freertos/port/xtensa/portasm.S:231
另外ESP-S3-EYE dev board V1.1 仅支持 80MHz flash and spram?
esp-who/examples/human_face_detection/web报错!
