尝试过手动进入下载模式,仍不能解决该问题。
Traceback信息如下:
File "C:\Espressif\python_env\idf5.0_py3.8_env\lib\site-packages\esptool\__init__.py", line 1031, in _main
main()
File "C:\Espressif\python_env\idf5.0_py3.8_env\lib\site-packages\esptool\__init__.py", line 831, in main
operation_func(esp, args)
File "C:\Espressif\python_env\idf5.0_py3.8_env\lib\site-packages\esptool\cmds.py", line 580, in write_flash
esp.flash_defl_block(block, seq, timeout=timeout)
File "C:\Espressif\python_env\idf5.0_py3.8_env\lib\site-packages\esptool\loader.py", line 131, in inner
return func(*args, **kwargs)
File "C:\Espressif\python_env\idf5.0_py3.8_env\lib\site-packages\esptool\loader.py", line 1030, in flash_defl_block
self.check_command(
File "C:\Espressif\python_env\idf5.0_py3.8_env\lib\site-packages\esptool\loader.py", line 435, in check_command
val, data = self.command(op, data, chk, timeout=timeout)
File "C:\Espressif\python_env\idf5.0_py3.8_env\lib\site-packages\esptool\loader.py", line 404, in command
p = self.read()
File "C:\Espressif\python_env\idf5.0_py3.8_env\lib\site-packages\esptool\loader.py", line 337, in read
return next(self._slip_reader)
StopIteration
A fatal error occurred: The chip stopped responding.
