NetBIOS not working with SoftAP?
A6ESPF
Postby A6ESPF » Mon Mar 27, 2023 10:44 am
When I connect my ESP32 to my home LAN and use its NetBIOS name to access the device, it works perfectly. However, when I connect to the device's access point, I can't look it up anymore using NetBIOS and I have to type in 192.168.4.1 to access the device. Why doesn't NetBIOS work with SoftAP?
Re: NetBIOS not working with SoftAP?
Postby Sprite » Tue Mar 28, 2023 12:38 am
Are you running something specific that handles NetBIOS on your ESP32? Because if not, it's more likely either mDNS or your router that does DHCP->DNS that allows you to resolve the domain name. (Note that mDNS is also something you have to actively enable/install in your ESP32, so if you don't do that, it's likely your router.)
A6ESPF
Postby A6ESPF » Thu May 04, 2023 11:23 am
Sorry for the late reply. I first initialize NetBIOS on ESP32 using netbiosns_init function. Then I set the NetBIOS name using netbiosns_set_name function. This topic (viewtopic.php?f=13&t=32062) was also started by me, so you can see how I initialized NetBIOS on ESP32.
Users browsing this forum: Baidu [Spider], Qwantbot and 4 guests
