BLE does not connect/restart after light sleep
deniswsrosa
Postby deniswsrosa » Mon Apr 03, 2023 7:53 pm
I went through a lot of documentation and tutorials, but I could not find yet what is the correct way of shutting down BLE before a light sleep and how to restart if after wakeup. Could you guys give me any ideas of what is wrong with the following code?
    Based on Neil Kolban example for IDF: https://github.com/nkolban/esp32-snippets/blob/master/cpp_utils/tests/BLE%20Tests/SampleWrite.cpp
    Ported to Arduino ESP32 by Evandro Copercini
#include <BLEDevice.h>
#include <BLEUtils.h>
#include <BLEServer.h>
#include "esp_wifi.h"
#include "esp_bt_main.h"
#define uS_TO_S_FACTOR 1000000ULL  /* Conversion factor for micro seconds to seconds */
#define TIME_TO_SLEEP  2
// See the following for generating UUIDs:
// https://www.uuidgenerator.net/
#define SERVICE_UUID        "4fafc201-1fb5-459e-8fcc-c5c9c331914b"
#define CHARACTERISTIC_UUID "beb5483e-36e1-4688-b7f5-ea07361b26a8"
#define LED_PIN 2
#define BTN_PIN 12
int deviceConnected = false;
int counter = 0;
class MyCallbacks: public BLECharacteristicCallbacks {
   void onConnect(BLEServer* pServer) {
      deviceConnected = true;
      Serial.println("device connected");
      BLEDevice::startAdvertising();
    void onDisconnect(BLEServer* pServer) {
      Serial.println("device disconnected");
    void onWrite(BLECharacteristic *pCharacteristic) {
      std::string value = pCharacteristic->getValue();
      if (value.length() > 0) {
        Serial.print("*********");
        Serial.print(value.c_str());
        Serial.print("-");
        Serial.print(atoi(value.c_str()));
        Serial.print("-");
        if(atoi(value.c_str())==1)
          digitalWrite(LED_PIN,HIGH);
          Serial.print("LEDON");
        else
          digitalWrite(LED_PIN,LOW);
          Serial.print("LEDOFF");
        Serial.println("*********");
BLECharacteristic *pCharacteristic;
void startBluetooth() {
  BLEDevice::init("BLE_DEVICE");
  BLEServer *pServer = BLEDevice::createServer();
  BLEService *pService = pServer->createService(SERVICE_UUID);
  pCharacteristic= pService->createCharacteristic(
                                          CHARACTERISTIC_UUID,
                                          BLECharacteristic::PROPERTY_READ |
                                          BLECharacteristic::PROPERTY_WRITE |
                                          BLECharacteristic::PROPERTY_NOTIFY
  pCharacteristic->setCallbacks(new MyCallbacks());
  pCharacteristic->setValue("Hello World");
  pService->start();
  BLEAdvertising *pAdvertising = pServer->getAdvertising();
  pAdvertising->start();
  counter = 0;
  esp_wifi_set_mode(WIFI_MODE_NULL);
  pinMode(LED_PIN,OUTPUT);
  startBluetooth();
int prevVal = LOW;
bool wasSleeping = false;
  if(wasSleeping) {
    startBluetooth();
  int currentVal = digitalRead(BTN_PIN);
  if(currentVal!=prevVal)
    prevVal=currentVal;
    if(currentVal==HIGH)
      int value = 10;
      pCharacteristic->setValue((uint8_t*)&value, 4);
        pCharacteristic->notify();
    else
       int value = 0;
  // delay(100);
  // counter++;
  if(counter > 160) {
    counter = 0;
    esp_bluedroid_disable();
    esp_bluedroid_deinit();
    btStop();
    delay(1000);
    esp_sleep_enable_timer_wakeup(TIME_TO_SLEEP * uS_TO_S_FACTOR);
    Serial.println("Going to light sleep now");
    esp_light_sleep_start();
    esp_bluedroid_init();
    esp_bluedroid_enable();
    btStart();
After the first sleep, I'm not able to connect via BLE anymore
Users browsing this forum: Google [Bot] and 8 guests
