Communicating with End Devices Connected to SoftAP using ESP32S3 and RNDIS.
bluestar_
Postby bluestar_ » Tue Apr 04, 2023 7:34 am
Hello, I'm looking for a way to communicate with end devices connected to SoftAP using ESP32S3 and RNDIS.
I have a question about the following.
  • Is it possible to communicate with an end device connected to SoftAP using ESP32S3 and RNDIS?
  • Please advise me on how to implement the following
I am currently trying to implement a Windows Mobilehotspot-like feature using ESP32S3.
I have several devices connected to the SSID of the ESP32S3's SoftAP feature.
I want to use a USB connection (RNDIS) between the PC and the ESP32 to allow the PC and the terminals connected to the ESP32 to communicate.
I assume the following
PC <-RNDIS-> ESP32S3 <-WiFi(SoftAP)-> End Devices
Each of the following seemed to be useful.
The USB Dongle can communicate through RNDIS during STA, but even if I start SoftAP at the same time and connect the end device, the end device cannot communicate with either the PC or the router.
The wifi_router does not seem to be able to communicate via RNDIS.
Thank you,
MTRobin
Re: Communicating with End Devices Connected to SoftAP using ESP32S3 and RNDIS.
Postby MTRobin » Mon Sep 16, 2024 7:03 pm
Have you found a solution? I am in a similar situation.
nopnop2002
Contact:
Postby nopnop2002 » Sat Oct 19, 2024 12:00 am
This might work.
This is a sample of using ESP32 as a WiFi repeater.
https://github.com/espressif/esp-idf/tr ... ork/eth2ap
ESP32S3 don't have Internal EMAC, so it is necessary to use SPI Ethernet.
End devices can communicate directly with the PC.
PC <-Ethernet-> ESP32S3 <-WiFi(SoftAP)-> End Devices
