During ESP boot, GPIO26 turns briefly high.
This behavior interferes with the peripheral connected to that pin.
Is there any way to prevent the pin from turning high.
ESP32S3 GPIO26 turns high during boot
Re: ESP32S3 GPIO26 turns high during boot
Maybe you could add a strong pull-down resistor since there is a weak pull-up inside GPIO26.
Jonathan2892
Hey,
you can look up all the pin-states at RESET in the technical reference: https://www.espressif.com/sites/default ... ual_en.pdf
In table 6-3 there is a column called RST. Below the table is the explanation what the numbers in that column mean.
Maybe that helps to choose which pin to use for your peripherals.
Best, J
Best, J
Users browsing this forum: Perplexity-User and 5 guests
