Lyrat's dueros no work, wifi ssid not catught! menuconfig setup right!
albertgong11
Postby albertgong11 » Tue Apr 11, 2023 3:34 am
ELF file SHA256: db275acd937f551d
Rebooting...
ets Jul 29 2019 12:21:46
rst:0xc (SW_CPU_RESET),boot:0x1f (SPI_FAST_FLASH_BOOT)
configsip: 0, SPIWP:0xee
mode:DIO, clock div:1
load:0x3fff0030,len:7016
load:0x40078000,len:15676
ho 0 tail 12 room 4
load:0x40080400,len:4516
0x40080400: _init at ??:?
entry 0x400806b8
I (29) boot: ESP-IDF v4.4.4-dirty 2nd stage bootloader
I (29) boot: compile time 11:07:02
I (29) boot: chip revision: v3.0
I (33) boot_comm: chip revision: 3, min. bootloader chip revision: 0
I (40) qio_mode: Enabling default flash chip QIO
I (45) boot.esp32: SPI Speed : 80MHz
I (50) boot.esp32: SPI Mode : QIO
I (54) boot.esp32: SPI Flash Size : 4MB
I (59) boot: Enabling RNG early entropy source...
I (64) boot: Partition Table:
I (68) boot: ## Label Usage Type ST Offset Length
I (75) boot: 0 nvs WiFi data 01 02 00009000 00006000
I (82) boot: 1 phy_init RF data 01 01 0000f000 00001000
I (90) boot: 2 factory factory app 00 00 00010000 00310000
I (97) boot: End of partition table
I (102) boot_comm: chip revision: 3, min. application chip revision: 0
I (109) esp_image: segment 0: paddr=00010020 vaddr=3f400020 size=6bd30h (441648) map
I (239) esp_image: segment 1: paddr=0007bd58 vaddr=3ffb0000 size=04228h ( 16936) load
I (244) esp_image: segment 2: paddr=0007ff88 vaddr=40080000 size=00090h ( 144) load
I (245) esp_image: segment 3: paddr=00080020 vaddr=400d0020 size=153188h (1388936) map
I (636) esp_image: segment 4: paddr=001d31b0 vaddr=40080090 size=18a30h (100912) load
I (681) boot: Loaded app from partition at offset 0x10000
I (681) boot: Disabling RNG early entropy source...
I (693) psram: This chip is ESP32-D0WD
I (693) spiram: Found 64MBit SPI RAM device
I (693) spiram: SPI RAM mode: flash 80m sram 80m
I (698) spiram: PSRAM initialized, cache is in low/high (2-core) mode.
I (705) cpu_start: Pro cpu up.
I (709) cpu_start: Starting app cpu, entry point is 0x40081798
0x40081798: call_start_cpu1 at E:/esp-idf/Espressif/frameworks/esp-idf-v4.4.4/components/esp_system/port/cpu_start.c:148
I (701) cpu_start: App cpu up.
I (1191) spiram: SPI SRAM memory test OK
I (1199) cpu_start: Pro cpu start user code
I (1199) cpu_start: cpu freq: 240000000
I (1199) cpu_start: Application information:
I (1202) cpu_start: Project name: esp_dueros
I (1207) cpu_start: App version: v2.5-12-ga84b88b-dirty
I (1214) cpu_start: Compile time: Apr 11 2023 11:19:55
I (1220) cpu_start: ELF file SHA256: db275acd937f551d...
I (1226) cpu_start: ESP-IDF: v4.4.4-dirty
I (1231) heap_init: Initializing. RAM available for dynamic allocation:
I (1239) heap_init: At 3FFAE6E0 len 00001920 (6 KiB): DRAM
I (1245) heap_init: At 3FFB7470 len 00028B90 (162 KiB): DRAM
I (1251) heap_init: At 3FFE0440 len 00003AE0 (14 KiB): D/IRAM
I (1258) heap_init: At 3FFE4350 len 0001BCB0 (111 KiB): D/IRAM
I (1264) heap_init: At 40098AC0 len 00007540 (29 KiB): IRAM
I (1270) spiram: Adding pool of 4084K of external SPI memory to heap allocator
I (1279) spi_flash: detected chip: generic
I (1283) spi_flash: flash io: qio
W (1287) spi_flash: Detected size(8192k) larger than the size in the binary image header(4096k). Using the size in the binary image header.
I (1301) cpu_start: Starting scheduler on PRO CPU.
I (1311) spiram: Reserving pool of 32K of internal memory for DMA/internal allocations
I (1351) DUEROS: ADF version is v2.5-12-ga84b88b-dirty
I (1351) gpio: GPIO[19]| InputEn: 1| OutputEn: 0| OpenDrain: 0| Pullup: 1| Pulldown: 0| Intr:3
E (1361) gpio: gpio_install_isr_service(449): GPIO isr service already installed
I (1381) gpio: GPIO[21]| InputEn: 0| OutputEn: 1| OpenDrain: 0| Pullup: 0| Pulldown: 0| Intr:0
I (1381) ES8388_DRIVER: init,out:02, in:00
I (1381) gpio: GPIO[36]| InputEn: 1| OutputEn: 0| OpenDrain: 0| Pullup: 1| Pulldown: 0| Intr:3
I (1391) gpio: GPIO[39]| InputEn: 1| OutputEn: 0| OpenDrain: 0| Pullup: 1| Pulldown: 0| Intr:3
W (1421) PERIPH_TOUCH: _touch_init
I (1421) SDCARD: Using 1-line SD mode, base path=/sdcard
I (1451) SDCARD: CID name !
E (1901) DISPATCHER: exe first list: 0x0
I (1901) DISPATCHER: dispatcher_event_task is running...
I (1911) AUDIO_THREAD: The wifi_serv task allocate stack on external memory
I (1921) wifi:wifi driver task: 3ffcd2a8, prio:23, stack:6656, core=0
I (1921) system_api: Base MAC address is not set
I (1921) system_api: read default base MAC address from EFUSE
I (1941) wifi:wifi firmware version: 6567a16
I (1941) wifi:wifi certification version: v7.0
I (1941) wifi:config NVS flash: enabled
I (1941) wifi:config nano formating: disabled
I (1941) wifi:Init data frame dynamic rx buffer num: 32
I (1951) wifi:Init management frame dynamic rx buffer num: 32
I (1951) wifi:Init management short buffer num: 32
I (1961) wifi:Init static tx buffer num: 16
I (1961) wifi:Init tx cache buffer num: 32
I (1961) wifi:Init static rx buffer size: 1600
I (1971) wifi:Init static rx buffer num: 16
I (1971) wifi:Init dynamic rx buffer num: 32
I (1981) wifi_init: rx ba win: 16
I (1981) wifi_init: tcpip mbox: 32
I (1981) wifi_init: udp mbox: 6
I (1991) wifi_init: tcp mbox: 6
I (1991) wifi_init: tcp tx win: 5744
I (2001) wifi_init: tcp rx win: 5744
I (2001) wifi_init: tcp mss: 1440
I (2001) wifi_init: WiFi/LWIP prefer SPIRAM
I (2011) phy_init: phy_version 4670,719f9f6,Feb 18 2021,17:07:07
I (2101) wifi:mode : sta (b4:8a:0a:74:3e:04)
I (2101) wifi:enable tsf
I (159,tid:3ffdd738) lightduer_session.c( 44):random = 75933
I (11921) WIFI_SERV: Connect to wifi ssid: , pwd:
ESP_ERROR_CHECK failed: esp_err_t 0x300a (ESP_ERR_WIFI_SSID) at 0x400922a4
0x400922a4: _esp_error_check_failed at E:/esp-idf/Espressif/frameworks/esp-idf-v4.4.4/components/esp_system/esp_err.c:42
file: "E:/esp-idf/Espressif/frameworks/esp-adf/components/wifi_service/src/wifi_service.c" line 421
func: wifi_task
expression: esp_wifi_connect()
abort() was called at PC 0x400922a7 on core 0
0x400922a7: _esp_error_check_failed at E:/esp-idf/Espressif/frameworks/esp-idf-v4.4.4/components/esp_system/esp_err.c:43
Backtrace: 0x40082411:0x3f80b230 0x400922b1:0x3f80b250 0x400973d1:0x3f80b270 0x400922a7:0x3f80b2e0 0x400e055f:0x3f80b3000x40082411: panic_abort at E:/esp-idf/Espressif/frameworks/esp-idf-v4.4.4/components/esp_system/panic.c:408
0x400922b1: esp_system_abort at E:/esp-idf/Espressif/frameworks/esp-idf-v4.4.4/components/esp_system/esp_system.c:137
0x400973d1: abort at E:/esp-idf/Espressif/frameworks/esp-idf-v4.4.4/components/newlib/abort.c:46
0x400e055f: wifi_task at E:/esp-idf/Espressif/frameworks/esp-adf/components/wifi_service/src/wifi_service.c:421 (discriminator 1)
Rebooting...
ho 0 tail 12 room 4
entry 0x400806b8
ClearCommError failed (PermissionError(13, '???????????????', None, 5))
repeat rebooting, setup menicofig's wifi and password right. but not showing, and lyrat setup right, duer os profile setup ok!
Any idea?
