UART reading float numbers
emanos
Postby emanos » Tue Apr 11, 2023 8:15 am
Hey everyone,
I would like to ask for your help. I am writing code in Arduino, yet i utilize the <driver/uart.h> library and i have set up the uart as following:
  uart_config_t uart_config_0 = {
  .baud_rate = 115200,
  .flow_ctrl = UART_HW_FLOWCTRL_DISABLE
uart_param_config(UART_NUM_0, &uart_config_0);
uart_set_pin(UART_NUM_0, TX_UART0, RX_UART0, UART_PIN_NO_CHANGE, UART_PIN_NO_CHANGE);
uart_driver_install(UART_NUM_0, BUF_SIZE*2, 0, 0, NULL, 0);
Then, i try to read data and echo them as following:
int len = uart_read_bytes(UART_NUM_0, dataR, 1024, 1000);
  if (len > 0)
  	uart_write_bytes(UART_NUM_0, dataR, strlen(dataR));
My plan was to take all 4 bytes that a float is consisted of and using memcpy try and structure the float that i would finally print.
To be honest i am having trouble even with reading plain data (not floats) in general, so if you can help me with even some echo, i would appreciate it.
Thanks in advance
corz.org
Contact:
Re: UART reading float numbers
Postby corz.org » Tue Apr 11, 2023 9:06 am
If it's not huge, it's best to post all your code, as well as how your project is setup (e.g. where is this data coming from?). You can't read floats from the UART, per se. Only data bits.
There may be a better way to do what you are trying to do.
Is this for RS-232? Or would Serial functions perhaps be more suitable? Or maybe SPI?
I would start somewhere like here: https://en.wikipedia.org/wiki/Universal ... ransmitter
Users browsing this forum: Bytespider, Google [Bot] and 5 guests
