I have set myself an ambitious project in relation to VGA and Esp32 (using a library of course, maybe you know it), but using both Esp32 Cores in their true and maximum computing capacity.
Unfortunately FreeRTOS is a big obstacle to get to such a point, I can tolerate the fact that it consumes a considerable amount of RAM, but what I don't find funny is that it is running SOMETHING behind the scenes (at this point I don't know what it does or so, I don't know if it's the Watchdog, interruptions, some light sub-task, I don't know).
Between my investigations on the internet, I managed to use both Cores without the Watchdog running (or so I think) and without having to use some kind of delay for... I don't know, I don't know why all the examples of the use of dual core must use delays so the Esp32 wouldn't crash, but I managed to avoid that
But there is a detail... For some unknown reason, Core 0 is a little less efficient than Core 1, I don't know why, would I have missed deactivating something from FreeRTOS? Or perhaps at the hardware level is it less efficient?
Here I show you some Benchmarks that I did, which use the I/O (to see if there are no performance losses for the use of VGA) and two different high consumption tasks (to see if the computing level is affected).
Code: https://gist.github.com/HiperDoo/c87624 ... dd003a73cd
1. Use Core 1 to calculate PI or Prime Numbers and use Core 0 for OUTPUT/INPUT GPIOs. (Values vary ~1ms)
Write timing is slower and Read is slower.
PI timing is perfect and Prime timing is perfect.
// For the Core 0
>>> BENCHMARK WRITE<<< Core: 0
* digitalWrite(): 6853 ms
* gpio_set_level(): 5927 ms
* GPIO.out_w1ts/t: 1009 ms
* REG_WRITE(): 1009 ms
// OR
>>> BENCHMARK READ <<< Core: 0
* digitalWrite(): 2019 ms
* gpio_get_level(): 1639 ms
* GPIO.in: 505 ms
* REG_READ(): 504 ms
// For the Core 1
>>> BENCHMARK PI <<< Core: 1
* PI: 3.141593
* Time: 38244 ms
// OR
>>> BENCHMARK PRIME <<< Core: 1
* Prime: 25997
* Time: 94846 ms
Write timing is perfect and Read is perfect.
PI timing is slower and Prime timing is slower.
// For the Core 1
>>> BENCHMARK WRITE <<< Core: 1
* digitalWrite(): 6837 ms
* gpio_set_level(): 5914 ms
* GPIO.out_w1ts/t: 1007 ms
* REG_WRITE(): 1008 ms
// OR
>>> BENCHMARK READ <<< Core: 1
* digitalWrite(): 2013 ms
* gpio_get_level(): 1636 ms
* GPIO.in: 504 ms
// For the Core 0
>>> BENCHMARK PI <<< Core: 0
* PI: 3.141593
* Time: 40368 ms
// OR
>>> BENCHMARK PRIME <<< Core: 0
* Prime: 25997
* Time: 98676 ms
PI timing is perfect and Prime timing is slower.
* PI: 3.141593
* Time: 38244 ms
* Prime: 25997
* Time: 95070 ms
PI timing is slower and Prime timing is perfect.
* PI: 3.141593
* Time: 38334 ms
* Prime: 25997
* Time: 94846 ms
* digitalWrite(): 2052 ms
* gpio_get_level(): 1701 ms
* GPIO.in: 503 ms
* digitalWrite(): 2086 ms
* gpio_get_level(): 1690 ms
* GPIO.in: 503 ms
>>> BENCHMARK WRITE <<< Core: 0
* digitalWrite(): 7860 ms
* gpio_set_level(): 7942 ms
* digitalWrite(): 4076 ms
* gpio_get_level(): 1708 ms
* GPIO.in: 504 ms
* digitalWrite(): 2051 ms
* GPIO.in: 504 ms
* digitalWrite(): 2074 ms
* gpio_get_level(): 1689 ms
* GPIO.in: 504 ms
* digitalWrite(): 8868 ms
* gpio_set_level(): 6934 ms
* digitalWrite(): 2087 ms
* gpio_get_level(): 3698 ms
* GPIO.in: 504 ms
* GPIO.in: 504 ms
Obviously I will be attentive to your answers, but also to recommendations.
I know that they usually recommend not deactivating the Watchdog (although I don't know why, I haven't seen the reasons), but the least of my problems is that a task doesn't finish executing (that would be my logic problem).
