WifiManager preventing loop code from executing
PRO_GRAMMAR
Postby PRO_GRAMMAR » Wed Apr 19, 2023 6:00 pm
A little help here please.
This wifi manager has options for what to do at first run if no stored wifi credentials are found.
The AP_NONE option far as I can tell should allow code in the loop to continue running while AP portal is open but it doesn't. Please let me know what I'm missing.
thanks. Sketch and links to header and source files:
https://github.com/smurf0969/WiFiConnec ... iConnect.h
https://github.com/smurf0969/WiFiConnec ... nnect.cpp
[Codebox]
#include "WiFiConnect.h"
#include <WiFiClient.h>
#ifdef ARDUINO_ARCH_ESP8266
#include <ESP8266HTTPClient.h>
#else
#include <HTTPClient.h>
#endif
WiFiConnect wc;
// For internet connection
WiFiClient client;
HTTPClient http;
const int pin18=18;
void configModeCallback(WiFiConnect *mWiFiConnect) {
Serial.println("Entering Access Point");
void startWiFi(boolean showParams = false) {
wc.setDebug(true);
/* Set our callbacks */
wc.setAPCallback(configModeCallback);
//wc.resetSettings(); //helper to remove the stored wifi connection, comment out after first upload and re upload
AP_NONE = Continue executing code
AP_LOOP = Trap in a continuous loop - Device is useless
AP_RESET = Restart the chip
AP_WAIT = Trap in a continuous loop with captive portal until we have a working WiFi connection
if (!wc.autoConnect()) { // try to connect to wifi
/* We could also use button etc. to trigger the portal on demand within main loop */
wc.startConfigurationPortal(AP_NONE);//if not connected show the configuration portal
while (!Serial) {
delay(100);
Serial.println("....");
delay (5000);
startWiFi();
pinMode(pin18, OUTPUT);
digitalWrite(pin18, HIGH);
delay(500);
digitalWrite(pin18, LOW);
delay(500);
delay(100);
Serial.println("Testing with connection to internet...");
http.begin(client, "http://ftp.mirrorservice.org/sites/arch ... om/ubuntu/");
int httpCode = http.GET();
if (httpCode > 0)
// HTTP header has been send and Server response header has been handled
Serial.printf("[HTTP] GET... code: %d\n", httpCode);
// file found at server
if (httpCode == HTTP_CODE_OK)
Serial.println("HTTP_CODE_OK");
Serial.printf("[HTTP] GET... failed, error: %s\n", http.errorToString(httpCode).c_str());
http.end();
// Wifi Dies? Start Portal Again
if (WiFi.status() != WL_CONNECTED) {
if (!wc.autoConnect()) wc.startConfigurationPortal(AP_NONE);
delay (20000);
[/Codebox]
Users browsing this forum: Bing [Bot], ChatGPT-User and 2 guests
