Using tinyusb from a component
ghoti57
Postby ghoti57 » Sat Apr 22, 2023 2:23 pm
ESP-IDF 5.0.1
Windows 11
I can create a fairly trivial project using tinyusb that creates two cdc-acm serial ports and echoes output from each in the other (test.zip).
However if I try to move usb.c and usb.h into a component I can't get the system to build.
In the first instance i just moved usb.c and usb.h to components\usb
created components\usb\CmakeLists.txt
idf_component_register(
    SRCS "usb.c"
    INCLUDE_DIRS "."
and updated main\CMakeLists.txt
# See the build system documentation in IDF programming guide
# for more information about component CMakeLists.txt files.
idf_component_register([attachment=1]test.zip[/attachment]
    SRCS main.c
    REQUIRES usb
Attempting to build now produces the following errors
<path>/eclipse-workspace/test1/components/usb/usb.c:6:10: fatal error: tinyusb.h: No such file or directory
    6 | #include "tinyusb.h"
compilation terminated.
<path>/eclipse-workspace/test1/managed_components/espressif__esp_tinyusb/tinyusb.c:12:10: fatal error: esp_private/usb_phy.h: No such file or directory
   12 | #include "esp_private/usb_phy.h"
The first can be fixed by adding a REQUIRES line to components\usb\CMakeLists.txt
    SRCS "usb.c"
    INCLUDE_DIRS "."
    REQUIRES tinyusb
However, I can find no way to eliminate the second error.
I've tried moving idf_components.yml to various other parts of the project to no avail.
test1.zip is my latest component version
Anybody know how to get rid of this error please
test1.zip
Last build error with component
(3.24 KiB) Downloaded 183 times
test.zip
Simple working project
(2.65 KiB) Downloaded 203 times
ghoti57
Re: Using tinyusb from a component
Postby ghoti57 » Mon Apr 24, 2023 7:25 am
This really belongs under ESP-IDF so reposted there and closing this topic
