The code for the buttons look to be this:
#define BUTTON_BOOST 0x44
#define BUTTON_TIMER 0x46
#define BUTTON_POWER 0x4C
#define BUTTON_LOCK 0x4E
#define BUTTON_SELF_CLEAN 0x74And perhaps within that is the button code?
if (sendingKeyCode) {
if (totalBitsSent < 8) {
digitalWrite(dataPin, (buttonStatus << totalBitsSent) & 0x80 ? HIGH : LOW);
totalBitsSent++;
// FALLING edge 8 while sending keycode
else if (totalBitsSent == 8) {
// Receive ACK
pinMode(dataPin, GPIO_MODE_INPUT);
digitalWrite(dataPin, HIGH);
totalBitsSent++;
// FALLING edge 9 while sending keycode
else {
sendingKeyCode = false;
totalBitsSent = 0;
}Code: Select all
"data": {
"display": {
"status": "ON",
"brightness": 3,
"current_code": "."
"status": {
"power": "STANDBY",
"boost": "OFF",
"sleep": "OFF",
"o3_generation": "OFF",
"pump_low_flow": "OFF",
"low_salt": "OFF",
"high_salt": "OFF",
"service": "OFF"
"mode": {
"working": false,
"programming": false
}Code: Select all
"data": {
"powerStatus": "0x01",
"statusDigit1": "0x00",
"statusDigit2": "0x02",
"statusDigit3": "0x00",
"displayingDigit1": "0x00",
"displayingDigit2": "0x02",
"current_code": ".",
"readBuffer": "[0X68, 0X00], [0X49, 0XFF], [0X48, 0X01], [0X6C, 0X00], [0X49, 0XFF], [0X48, 0X01], [0X6A, 0X02], [0X49, 0XFF], [0X48, 0X01], [0X68, 0X00], [0X49, 0XFF], [0X48, 0X01], [0X6C, 0X00], [0X49, 0XFF], [0X48, 0X01], [0X6A, 0X02], [0X49, 0XFF], [0X48, 0X01], [0X68, 0X00], [0X49, 0XFF], [0X48, 0X01], [0X6C, 0X00], [0X49, 0XFF], [0X48, 0X01], [0X6A, 0X02], [0X49, 0XFF], [0X48, 0X01], [0X68, 0X00], [0X49, 0XFF], [0X49, 0XFF], [0X48, 0X01], [0X6C, 0X00], [0X48, 0X01], [0X6A, 0X02], [0X49, 0XFF], [0X48, 0X01], [0X68, 0X00], [0X49, 0XFF], [0X48, 0X01], [0X6C, 0X00], [0X49, 0XFF], [0X48, 0X01], [0X6A, 0X02], [0X49, 0XFF], [0X48, 0X01], [0X68, 0X00], [0X49, 0XFF], [0X48, 0X01], [0X6C, 0X00], [0X49, 0XFF], [0X48, 0X01], [0X6A, 0X02], [0X49, 0XFF], [0X48, 0X01], [0X68, 0X00], [0X49, 0XFF], [0X48, 0X01], [0X6C, 0X00], [0X49, 0XFF], [0X48, 0X01], [0X6A, 0X02], [0X49, 0XFF], [0X48, 0X01], [0X68, 0X00], [0X49, 0XFF], [0X48, 0X01], [0X6C, 0X00], [0X49, 0XFF], [0X49, 0XFF], [0X48, 0X01], [0X6A, 0X02], [0X49, 0XFF], [0X48, 0X01], [0X68, 0X00], [0X49, 0XFF], [0X48, 0X01], [0X6C, 0X00], [0X49, 0XFF], [0X48, 0X01], [0X6A, 0X02], [0X49, 0XFF], [0X48, 0X01], [0X68, 0X00], [0X49, 0XFF], [0X48, 0X01], [0X6C, 0X00], [0X49, 0XFF], [0X48, 0X01], [0X6A, 0X02], [0X49, 0XFF], [0X48, 0X01], [0X68, 0X00], [0X49, 0XFF], [0X48, 0X01], [0X6C, 0X00], [0X49, 0XFF], [0X48, 0X01], [0X6A, 0X02], [0X49, 0XFF], [0X48, 0X01], [0X68, 0X00], [0X49, 0XFF], [0X48, 0X01], [0X6C, 0X00], [0X49, 0XFF], [0X48, 0X01], [0X6A, 0X02], [0X49, 0XFF], [0X48, 0X01], [0X68, 0X00], [0X49, 0XFF], [0X48, 0X01], [0X6C, 0X00], [0X49, 0XFF], [0X49, 0XFF], [0X48, 0X01], [0X6A, 0X02], [0X48, 0X01], [0X68, 0X00], [0X49, 0XFF], [0X48, 0X01], [0X6C, 0X00], [0X49, 0XFF], [0X48, 0X01], [0X6A, 0X02], [0X49, 0XFF], [0X48, 0X01], [0X00, 0X00]",
"compilation_date": "Apr 27 2023",
"compilation_time": "16:20:36",
"otaUpdating": false,
"removeWifiConfig": false,
"machineON": true
"wifiReconnecting": false,
"readingMaster": true,
"sendingKeyCode": false
}The GitHub> https://github.com/jingsno/intex-swg-iot
